a good little chorus
Started by Dmoney, June 25, 2009, 10:22:51 PM
sjwebb90
I'm currently using a DIY Small Clone build
I have built it using the PCB from Tonepads  http://www.tonepad.com/getFile.asp?id=97
The key to getting the best from this unit  to replace the 3x 1uf electroylic caps to 1uf metal film, do the depth mod plus cap switchcing mod. Make sure sure that the components used are rated above 12V (i.e electroylics Tantalums 25V) and run it off a 12V supply for better headroom. Running it on 9V it sounds a bit dull, However, running it on 12V sound crystal clear and lush. Rate about 11 O'clock Depth 1 O'Clock.
The CE-2 Clone is also good http://www.tonepad.com/getFile.asp?id=101 and I would recommend adding the effect level mod.
got chorus,
and tonight at practice i busted out two parts that use it, including a volume roll off to clean up for one.
oh my word! when did i get so TECH!
