Author Topic: Which BKPs for my RG550 20th?  (Read 5661 times)
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
Re: Which BKPs for my RG550 20th?
« Reply #15 on: June 29, 2009, 12:50:59 PM »
Yeah guys, I´ve just ordered 2 MMs :)
Congratulations!
I restrung my RG back to concert pitch today (it was in drop C and sounded incredible in that tuning but the Edge trem couldn't really handle the intonation) and I've had loads of fun playing Steve Morse, Satriani and Andy Timmons. A bit high gain for those styles maybe but still great, great tone.
Quote from: LoyK
The single coil sounds pretty good Imo, so I´m not going to switch it at the moment; maybe later.
Take it from me that the Slowhand I replaced the stock SC with made a huge improvement, it's a real Strat sound but still manages to balance well with the MMs and the inbetween settings are so nice.
Go on. You know you want to.
I see a rainbow rising
Look there on the horizon
And I'm coming home
LoyK
« Reply #16 on: June 29, 2009, 06:25:30 PM »
If I like the MMs, I am going to upgrade my ESP Horizon II (´59/JB) in the near future, which would be a good chance to order a slowhand SC ;)
LoyK
« Reply #17 on: July 09, 2009, 03:06:35 PM »
Hi guys, the MMs have arrived:)
But after removing the pickguard, it seems that the 2 humbuckers of my Ibanez have 2 connectors only (+ ground), red and white cables. These 2 cables are connected to the 5-way switch. How can the humbuckers be splitted then?!  My BKPs are 4 conductor now; I need help how to connect them properly. Thanks in advance!
Edit: White and green cables of the BKPs are connected already; so can I use the remaining 3 cables similar to the Ibanez pickups? Red to red, ground to ground and white to black(BKP) or do I have to solder other cables of the BKPs together?
« Last Edit: July 09, 2009, 03:53:34 PM by LoyK »
« Reply #18 on: July 09, 2009, 06:29:15 PM »
The BKP cable has separate wires for the end of each coil, plus a bare ground/shield wire.  The Ibanez cable just has hot (red), ground and a coil split wire (white).
So this (I think!) is how the wiring should go:
Ibanez...................................BKP
Red........................................Red
White.....................................Green & White
Bare (ground)........................Black & Bare
LoyK
« Reply #19 on: July 09, 2009, 07:01:27 PM »
OK, that sounds good. Can any Ibanez-User approve that?
gingataff
« Reply #20 on: July 10, 2009, 01:43:23 AM »
I replaced the Ibanez 5-way switch (=rubbish) with a CRL one (=good) and wired it as PhillyQ says.
Black and bare to ground, red to the 'hot' tabs on the switch and green&white to the 'split/ground' tabs.
And I'm coming home
LoyK
« Reply #21 on: July 10, 2009, 09:48:30 AM »
Thank you!
I´ll leave the Ibz switch in there for the moment; maybe I´ll replace it soon, bypass the tonepot (don´t need it) and replace the vol pot and the condensator :)
I hope everything works in a few hours.
LoyK
« Reply #22 on: July 10, 2009, 03:33:42 PM »
Thanks for your help guys, everything works fine now!
And the Miracle Men(!) are kicking major ass with my VHT Sig:X (now Fryette); everything sounds so powerful and clear...it´s a dream:)
