Author Topic: Cap values - materials  (Read 9683 times)
Re: Cap values - materials
« Reply #15 on: July 03, 2009, 08:27:26 PM »
The Burr Brown opamps are generally very nice - I've used them in SD-1s with good results.
For a cheap and cheerful dual opamp upgrade, even going from a 4558 to a 4559 made a big difference in a EQ pedal I modded last year.
Keven
« Reply #16 on: July 03, 2009, 11:49:43 PM »
Yeah, i was introduced to them through the alums mod to my CS-3, and will also upgrade my SD-1 to this opamp.
I'm mainly building my own EQ pedal as a fun project, and it's an easy circuit to begin with, you just start with one frequency and go along with it.
from the way i see it, i can probably modify the circuit to 4 dual opamps. the trick is to power them all. (that's why quads have 7 pins by side right? one common VDC input for all 4 opamps) i can probably just look at the current pcb i have for the GGG project and mod a cut some traces and add jumper wires to get the power to where i want it and the pinouts to where i need them :D
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
jpfamps
    • http://www.jpfamps.com
« Reply #17 on: July 06, 2009, 05:35:04 PM »
Yes, the main issue will be sorting out how to power a pair of dual op amps instead of one quad opamp.
In a CS-3, I expect than the main issue would be noise. The Burr Brown is very low noise for a JFET input opamp. Distortion in the OPAn134 series, used sensibly, is hardly measurable below about 10k. The only other issue could be instability caused by poor rail decoupling degrading the audio signal, but I suspect this probably isn't an issue here.
Of the generally used op-amps the NE5442 is considered to be the best from a distortion and noise performance view point, and for this sort of application I don't there is much more performance benefit to be gained by going for more exotic (ie expensive) specimens.
In the SD-1 (and TS808, TS9 etc) one half of the dual op amp is being used in a clipping circuit, the other half being used more convenetionally as an active tone control. I suspect the main difference in sound between opamps in this circuit is due to how the opamp performs in the clipping circuit. This probably doesn't have much relation to the opamps qualities as an audio part, so a suck it see approach is definitely worth it here.
