Quote from: martinw on July 18, 2009, 06:59:40 PM
Quote from: HEAVIER THAN HELL on July 18, 2009, 12:40:52 PM
I've messed round with the same thing, but not PP yet - just // SE. What primary Z are you using with the ECC82s in PP - triodes are quite forgiving in this respect afaik.
The tones I got were really nice with the ECC82 output stage, but it wasn't quite as grunty as a pentode. I know most players I've spoken to weren't keen on using valve types they weren't familiar with, but I think better results could be had with pentodes such as 6SL7/6SN7 or maybe even a 6G6G or 6K6.
The primary Z is quite high, but possibly not as per the manual. Don't want to go into too much detail!
My results with the triodes have been excellent, and for selling-on I'm happier using common, current valves.
I know that data sheets will tell you to use a 50k primary in SE mode, or around 25k if you're paralleling the triodes. As for PP, I know the AX84 Firefly uses a 22.5k primary via a Hammond 125A OT, though many people seem to think it sounds better with a lower primary than that. Oh, and the Firefly is self-split PP, not the typical PP arrangement you see in a plexi for instance.
It's an interesting theme for sure, I'll have to get off my arse and get one built past prototype stage - my tests were just done with the 1w output stage added onto an existing amp.
