Author Topic: Trying to make my '62 Strat more authentic  (Read 10938 times)
Re: Trying to make my '62 Strat more authentic
« Reply #15 on: July 31, 2009, 03:29:37 PM »
I've been keeping quiet but I have some experimental sets and the 62 Custom sets are one that I have.  I was thinking that you would like them but didn't want to say anything as Tim hadn't finalized them yet.
fox5150
« Reply #16 on: July 31, 2009, 11:32:27 PM »
I checked with Tim first before talking about these and he was okay for me to post about them, as I didn't want to let the cat out of the bag, so to speak. He did say that he'd been making them as a custom option for a little while. If you don't mind me asking, what can I expect?
Thanks,
Simon
BigB
  • Let's rock !
« Reply #17 on: February 08, 2010, 04:44:00 PM »
Well the pickups arrived this morning, which is an unbelievable turn around for a custom wind!
I'm taking the lot to my luthier next weekend so will report back with how it all sounds.
I failed to spot the report - so, care to share your impressions on these pups ?
gordiji
« Reply #18 on: February 08, 2010, 08:18:58 PM »
What's the difference between the '62 set and others. Better still what are the spec's and what are they nearest to.
fox5150
« Reply #19 on: February 20, 2010, 11:29:49 PM »
Hi All,
Apologies for not coming back and giving my thoughts...
I'm not very good at describing things so please consider this! After using them in my main strat, pretty much exclusively since they've gone in, I can safely say that they are a massive improvement on the stock Texas Specials that came with the guitar. The sound is much more balanced and even across the spectrum, rather than that rather nasal "SRV" type sound which came stock. I know some people chase this sound but it's not for me.
Bridge pickup - I got this with a zinc baseplate. I still find that this pickup is too bright, it's not nasty but does give that typical strat bridge pickup sound. I get a lovely thicker sound with the tone wound back to about 6-7 and this is where I live for most of the songs.
Middle pickup - I will be completely honest, I hardly ever use the middle pickup as I've never really found anything to use it for on any of my strats. This is just habit more than anything else. It does combine beautifully with the bridge or neck pickup to give those classic in-between sounds. However, there is a slight volume drop when selecting the in-between sounds, which I understand is to be expected.
Neck pickup - this is the sound I was hunting for. It seems to me that a lot of people are chasing the John Mayer tone, particularly the "Gravity" track. Well I can tell you that this pickup has it in spades. Back the tone and volume of a smidge and it is so warm and full, but still with tons of clarity.
I really struggle to articulate how a guitar sounds and so the above isn't too descriptive. I think the best advocate is that the strat has become my main gigging instrument and everybody that I have played it to has asked about the pickups, with several people enquiring about how to get them.
To me, this is the perfect sounding sixties strat and is a staggering improvement over what came stock.
If there are any questions, I'll do my best to answer them
« Reply #20 on: February 21, 2010, 02:53:51 AM »
Great that you liked it!!
About the bridge pickup, perhaps a talk with Mr Tim you can see what can be done, like a rewind or something... Must of guys that I've talked that played Strats hardly used the bridge pickup...
« Reply #21 on: February 21, 2010, 03:03:55 PM »
Do you have any tone control on the bridge pickup?
I've been wiring my strats for a single master tone for years. I use tone controls a lot and I found this immediately made the bridge "fit in" better. However, I still only rarely used a bridge pickup on its own for years...
It was Irish Tours that converted me to the bridge pickup on its own. After that, I found that pickup height adjustments opened up the bridge on other sets.
I do have a major difference though - I use the middle on its own a lot. I tend to regard the neck and bridge as variations away from the middle. This means that I set my amps for the middle pickup as my "stock" tone. If I was setting an amp by concentrating on the neck pickup, I think I'd have serious problems with the bridge pickup like others seem to.
By the way - I thought you did a pretty good job of describing the pickups :D
« Last Edit: February 21, 2010, 03:05:33 PM by AndyR »
