Author Topic: Is £2000 for an amp "painfully expensive"?  (Read 45632 times)
Re: Is £2000 for an amp "painfully expensive"?
« Reply #60 on: August 31, 2009, 12:31:28 PM »
i like expensive amps.
i guess some people collect really expensive guitars. but i like poking around in amplifiers and I when we play i get asked about my amps and complimented on my tone, usually by other guitarists.
Played a Hiwatt Hi Gain 100 at the weekend and i wasn't that into it. Also played an Orange Rocker 50 a few weeks back, and i was slightly suprised by how that sounded, but i wasn't into that either.
the upper end of mass produced amps still have quality issues tone wise, well, at least the ones ive played. (mesa dual rectumfryers for example)
i guess having a 'one amp does it all' kinda rig is a bit style dependant. I couldnt get away with playing a lot of shows on a 1x12 with a 30watt head. I've used a 5150 via a 2x12 before and even that was a little awkward.
like you say, if it gets you closer to that tone in your head then thats cool and if it helps you get into thats cool.
lowest cost rig i used once was a stock DS-1 and EQ-7 into a HH 3 channel vocal pa (solid state) into a 4x12 cab.
CRUSHING! actually it didnt sound that bad!
nfe
« Reply #61 on: August 31, 2009, 07:17:36 PM »
The pros I've come across usually get their gear for free if they bother to mention it somewhere and have usually have enough money so that a room full of vintage guitars and amps is the norm. So I guess £2000 is sweet $%&# all to them comparatively if they actually had to buy it.
Then again so is a chalet in Switzerland, a penthouse overlooking Central Park, another chalet in Aspen, a house on Regents Park road and another in the LA hills.
Of course, it's gonna be less than 1% of proffessional musicians lucky enough to be in that position.
« Reply #62 on: August 31, 2009, 11:27:39 PM »
Classic fallacious conclusion: "The sound at most pub gigs is poor, so there's no point buying decent gear."
hahahaha, circular logic at its best.
« Reply #63 on: September 01, 2009, 12:34:25 AM »
taken a step further... don't switch the jukebox off and tell the band to stay at home.
« Reply #64 on: September 01, 2009, 12:53:06 AM »
I don't think anyone actually said "the sound at most pub gigs is poor so there's no point buying decent gear".  Just that the sound at most pub gigs (and gigs in general) is poor.  What you spend on gear is up to you.
mikeluke
« Reply #65 on: September 01, 2009, 07:26:36 AM »
And that most of the punters do not notice the fact!
I would NEVER advocate not spending money on good equipment if you can afford it - don't let a bunch of tone deaf punters get in the way of a good GAS session!
Mike
Mules, Riff-Raff
jpfamps
    • http://www.jpfamps.com
« Reply #66 on: September 01, 2009, 08:40:44 PM »
Some very interesting points most of which I would largely agree with.
Notwithstanding the fact that a) I almost never buy any guitars/amps new, and b) that I would rather play the  Blond Tolex Bassman shown in an earlier post than any Rivera amp, I don't see £2k as completely off the wall.
Regardless, I really can't get that worried about the price of gear, especially of that I'm never going to buy...
I would agree, many of pro guys I know don't have that expensive kit, mainly because they don't earn much. Furthermore, many bands hire backline, so they tend to use easily sourced amps, which is mainly Fender or Marshall. They also don't tend to use channel switching amps........
The people I know with the most valuable gear are either collectors, semi-pros using their hobby to subsidize their gear purchases, or guitar dealers.
Part of the reason pro gear is more expensive (and don't just mean guitars and amps, look at say tools) is that it is built to last and with stand the inevitable (ab)use.
The first decent guitar I bought was a USA Strat back in 1989. It was my main guitar for several years and at one stage I was doing 100-150 gigs a year. It never let me down. At the same time I also had a Squier Silver series, and very quickly parts started to fail on it, eg switch, pots, even though I was only using as a spare, or for the occassional gig.
Bottom line is, to find the true cost of an item you need to consider the lifetime cost of a purchase, which includes maintenance, depreciation etc (and why I by second-hand gear!).
Guitars are more labour intensive, and have multiple price variables, whereas amps are fairly straightforward to manufacture and have a finite production cost. Did the Rivera cost £700 more to make, or take 4 times as long to make as a Marshall DSL 50 combo? I doubt it.
I can't say I agree with this. Amps can be very labour intensive. Rivera amps, from what I understand, are hand soldered. This is far more labour intensive than using a machine to stuff the board and wave soldering.
There are just as many multiple price variables on an amp than a guitar eg What do you use for the chassis? Mild steel, aluminium, stainless steel. What thickness? What coating/ passivationg do you use? What specification do you have your transfomers made to etc. What specifications do you have your PCBs made to? Do you mount pots on the PCB, etc.
Further more a manufacturer such as Rivera WILL be complying with all the necessary safety regs, testing, RoHS etc. This costs alot of money. I certainly know of at least 2 US manufacturers whose amps are being sold in the UK that don't comply to RoHS and contravene EU safety regulations (not to say that they are unsafe).
There are reasons for using a PCB other than reducing cost (although obviously if you are making an amp as cheaply as possible in volume you would of course use a PCB). PCBs provide the best reproducibility of manufacture.
The top end PCBs, as used by THD and Rivera, are at least as expensive to produce as say eyelet board, and development costs become more significant at lower production runs. Furthermore, using hand soldering on a PCB can be as labour intensive as say eyelet ot turret board, especially if the pots and valve sockets are mounted off the board, which they should be for maximum reliability.
Regardaing the comparison of the price difference between the Rivera and the Marshall DSL50, a fairer comparison would be to compare the US price of the Marshall with the UK price of the Rivera.
As for differences in build quality, I'm afraid the Marshall is a very poor second.....
« Last Edit: September 01, 2009, 08:43:06 PM by jpfamps »
« Reply #67 on: September 01, 2009, 08:47:11 PM »
Is that simply by not using lead free solder - which breaks down and fails after a while anyway?
jpfamps
« Reply #68 on: September 01, 2009, 09:06:59 PM »
Yes by not using lead-free solder they are contavening RoHS. They also may be using non-RoHS parts (although it's impossible to tell be looking at them).
Features that contravene EU regs include: not using a detachable IEC mains lead, the mains earth bond should be a threaded bolt welded to the chassis, all transformer secondaries should be fused (to be fair most manufacturers don't do this as it completely daft, eg fusing the bias supply).
gordiji
« Reply #69 on: September 01, 2009, 09:20:03 PM »
yes , obviously.I'm sure it's good although the youtube vid i just watched didn't sound so convincing.Now my engl screamer 50 is a 1x12 combo and with it's superb footswitch gives clean crunch,chrunchier and overdrive, 2 channels
'4sounds each with a footswitchable volume boost and reverb.Cost 900sterling altogether.I bet its as good or better
and its made in the fatherland! But for 2grand I could buy 2 of them and an AB pedal giving 8 footswitchable sounds
each with available boost, this i guarantee would piss all over it!
« Reply #70 on: September 01, 2009, 09:50:58 PM »
agreed. Or the UK price of the marshall compared to the US price of the rivera.
« Reply #71 on: September 01, 2009, 10:10:11 PM »
What upsets me is when UK made goods are cheaper abroad - that I can't understand
It happened with Rover Cars in the 80s and 90s and I'm sure it still happens today
jpfamps
« Reply #72 on: September 01, 2009, 10:22:58 PM »
Not with Rover cars it doesn't......
I suspect some form of Govt. subsidy was involved here. Looking at the economics of the car industry I really can't see how any money is made making cars.
dano
« Reply #73 on: September 02, 2009, 08:49:31 AM »
If you have the disposable income and a decent rehersal space / garage / music room to turn it up and do it justice, then buying a  £2K amp isn't 'painfully expensive' surely.
I've personally never spend more than £500 on an amp as to me it's the 'makey louder' part of my rig, but I do have about £2K worth of FX pedals though. :P
« Reply #74 on: September 02, 2009, 09:48:03 AM »
I've been watching this thread with great interest, but with not a lot to say, until jpfamps great post above :D
A big +1 from me on this in particular:
... I don't see £2k as completely off the wall.
£2k for that particular amp is, for me personally, "painfully expensive" :lol:
But would £2k be over the top for the right amp for me? If I needed an amp, and the one I really wanted after careful research was £2k, probably not... but I suspect the amp I'd want is more likely to be in the 500-1000 bracket.
Actually, if I was to gig again, the amp I'd want behind me would be my 25 year-old Laney Protube 50w MV 1x12 combo overhauled and serviced - and if I was about to get that done, I would be more than happy paying the equivalent of a new amp or more to get to get it done... (I've even been wondering recently, even though I have no need of it operational at present, how the hell to get it up to Denmark St for you to look at it jpfamps  - no transport, and it weighs a flippin ton :lol:)
By the way, "many of pro guys I know ... also don't tend to use channel switching amps..."
I don't know any anymore, but from previous experience I have to agree - although I use modellors etc for home practice/recording now, a gigging amp for me would have to be single channel.
I tried switching amps, and it just wasn't worth the hassle for me. I want a decent tone that I can control with the guitar and possibly a boost pedal of some sort (I even use patches on my modellors like this). Channel switching amps seemed like a brilliant idea until I tried them. In practice, they seemed to give me 2, or 3, "ok-but-no-cigar" sounds that always needed loads of @rsing about in sound-checks. The single channel route gave me a sh1thot basic tone I could use for 2-3 hours without getting bored/frustrated with it, leaving me free to perform.
