What delays are you guys using?
Started by hunter, September 07, 2009, 06:56:26 PM
marantz1300
I have two tape echo's,a WEM and a Melos.I also have Danelectre ,Boss and Arion pedals. The one I use 99% of the time is the cheap ,plastic Arion SAD1. It has a lovely warm lush  anolouge tone, without any of the noise problems of the tape echos or the sterility of the digital delays.I use it straight into my Super Lead(no loop),but use the loop on my Hiwatt.
Lew
#31
Quote from: Twinfan on September 08, 2009, 08:54:56 AM
Hence Martin is working on the external loop system for me.....
And hopefully it will be available for anyone to order?  8)
Quote from: Antag on September 08, 2009, 01:19:59 PM
Parallel or series loop? umm, parallel I think, though I have the FX mix pot on 100%
if it's the same loop as on my savage se, i think that makes it serial (setting it to 100% wet, that is). I think... i could be wrong. :lol:
Quote from: Lew!! on September 08, 2009, 09:01:29 PM
Yep, that's the idea....
mikey5
I think the subdecay echobox is the ultimate delay
blackie
What it says in the thread title, which delays do you use?
BOSS DD-3
Use them in front or in loop?
LOOP
SERIES I THINK
Multiple delays for different toanZ?
JUST FOR MY SOLOS
Tap tempo or manual adjustments?
MANUAL...ONE SETTING ala PAUL GILBERT
Do you tweak it a lot or just one setting and go?
NO I LIKE IT THE WAY IT SOUNDS
I wanna know it all!
OK OK I CHEATED IN MY MATH EXAMS WHEN I WAS 14...
Groove Cartel
TC Electronics Nova Repeater all the way. Can be run series or parallel, has a tap tempo that sense's your strumming and plenty of modes. Very good high quality, affordable delay unit.
[url="//www.groovecartel.co.uk"]www.groovecartel.co.uk[/url]
www.vanquishguitars.co.uk
I'm not really much of a fan of delay - the only one I really liked was an old EH Memory Man, but even then it was limited to easing a little bit into the mix when recording.
I prefer reverb in general for adding ambience.
Quote from: HEAVIER THAN HELL on September 09, 2009, 12:53:36 PM
and which reverb are you using?
sjwebb90
When using the Cornford Hellcat I use the internal built in reverb.
When using the Cornford MK50II I am currently using a Mr Springgy.
Quote from: Groove Cartel on September 09, 2009, 12:53:32 PM
I must say that the Nova Repeater seems mighty intriguing. Lots of possibilities and yet a very reasonable price.
Quote from: hunter on September 11, 2009, 06:36:56 AM
The built in one in my amp. 6 spring (2X3) Acutronics unit.
There's a reverb on the RE-20 that sucks just as much as the one on the original RE-201.  :lol: So I never use that.
camf
T Rex Reptile in the loop... it is ace.
SchonFan83
I change 'em out often--get bored easily...though I've never been into the digital delays much.
I love older Ibanez/Maxon AD99 And AD999.
I'm currently using an MXR Carbon Copy.
When I get a little extra scratch I will probably either spring for another Maxon or an MG Pedals Thats Echo Folks.
Frank
still using my ancient Quadraverb, from the days when I learned how to tempo-match the delay times to sound like U2
barely use it now though, it's just a few extra flashing LEDs in the rack these days
