Krank sweep control
Started by Dmoney, September 19, 2009, 05:55:27 PM
Copperhead
HAhahahahahha!!1!!!1111 :lol:
Of course if they see a cracked solder joint they re-solder it. I think the silicone is a preventative, to prevent movement and absorb shock in areas they have noticed have a trend to have problems for some reason. I seem to recall when Patrick was gooping my amp, he said something like "I noticed I've had a half dozen amps in the last year that came in for repair that had a cracked solder joint and arcing by this cap, so everyone that comes in for anything, I'm re-soldering that cap and gooping it so it can't move around for any reason..."
So that's how it happens, preventative I guess. There's a sticker on the side of the chassis that every date of service is recorded on, first couple are inspection and burn-in. If there's been any service or repairs after, it will be initialed and dated.
I just find it odd that they an issue with cracking solder joints. obviously most amps go through the same daily trials. my marshall 20 odd years old and it didnt have cracked solder joints. didnt have any goo either.
i just dont see the point in goop if the amp is well made to begin with. i also like the cable on that first pick I posted up that is almost tied in a knot around a bunch of capacitors. haha.
Copperhead
It's not that they're not well made, it's that Krank is stupidly overkill about reliability.
I doubt the cable around the caps left the factory that way, or you would see all of them like that.
