VHII question - neck version?
Started by GoDrex, October 28, 2009, 09:35:59 PM
GoDrex
I wonder if this will be OK as a bridge pickup. I'm going to try it anyway. I'm a little disappointed, but hopefully I'll like it anyway.
Quote from: GoDrex on October 29, 2009, 06:26:35 PM
Did you bought it new?
GoDrex
Quote from: GoDrex on October 28, 2009, 09:35:59 PM
I recently got a used VHII and it's supposed to be a bridge version - but I checked the resistance and it measures 8.37. I'm wondering if this could actually be a neck version. The BKP site doesn't list the resistance for the neck position pickups. I'm planning to use try this out in the bridge position of a dark LP copy anyway, but I'm just curious if I might have been mislead about this particular pickup.
So can anyone tell me what the resistance generally is for a neck VHII?
Quote from: GoDrex on October 29, 2009, 09:10:48 PM
Quote from: FELINEGUITARS on October 29, 2009, 05:39:09 PM
I have a VH2 neck pickup (new in a box ) and it reads 8.2k ohms
Shall be it
gibsonpager
Being the one who sold the pickup to the fellow, I'm becoming a bit perplexed by all of this. I ordered the VHII bridge pickup brand new straight from Bare Knuckles back in July, and specifically ordered it for the bridge position. I had it installed in my Gold Epiphone SG for about a month or so, but just felt like it wasn't what I was looking for. I had ordered both a Black Dog and a Riff Raff before for my Orville Les Paul, but really loved the Riff Raff, so I ordered one of those for my SG. Naturally, I still love it, and decided to sell the VHII, since there was no need to have it anymore.
When I had the VHII installed, I could easily tell that it felt much hotter than the Riff Raff or the SD Phat Cat that was in there before...very tight sounding, great harmonics, distorted much quicker, the VHII is a great pickup, just not what I was looking for; I guess you could say it was more of an impulsive/curiosity purchase. My advice would be to just install the pickup and let your ears decide, as someone else observed. I'm sorry the ohm rating wasn't what it's normally specified as on the site, but I can tell you that it feels hotter than the 8.3k or so that you found it to be. You'll never know until you try it, and I'm curious to find out your results. I've got a solid reputation on eBay and would never jip anyone like that. If it in fact was a neck pickup, it would be BKP's fault, and I would have been none the wiser. Please, give the pickup a try and see for yourself!
Regards,
Joseph
gingataff
Quote from: gibsonpager on October 30, 2009, 12:38:25 AM
Regards,
Joseph
I don't suppose you still have the warranty card with the DC reading on it do you?
I see a rainbow rising
Look there on the horizon
And I'm coming home
GoDrex
I decided to ask BKP about this and got a reply from Tim - thanks for the quick reply. Great customer service.  :)
QuoteYes that would be more in line with a neck spec VHII - no reason at all not to use it as a bridge, it should have a good PAF tone.
Quote from: GoDrex on October 30, 2009, 11:38:01 PM
Great!
So are you using it on bridge?
GoDrex
Well not right at this second. I haven't installed it yet. Soon I will.
gibsonpager
#24
Quote from: gingataff on October 30, 2009, 10:20:11 AM
Well, the gentleman I sold it to now has the warranty card and everything the pickup originally came with, but I do recall it saying 9.2k on the card. I'd hate to see disappointment out of all this, so I'm hoping he enjoys the pickup. If it truly was a neck version, I had no idea.  :?
gingataff
I'd say recheck the meter and measure it again to make sure, also check the wiring as BKP is a bit different to other makes.
And I'm coming home
GoDrex
I've measured it like 50 times. Not sure what you mean by check the wiring.
I have the warrenty card but that's meaning less to me since there's no identifying thing on the pickup to compare it to.
gingataff
I was just trying to make sure we've eliminated all possible room for error like a dodgy meter or that it's being measured in series rather than parallel (assuming it's 4 conductor).
But I take it that you know what you're doing and you've already covered those bases.
And I'm coming home
GoDrex
it's a single conductor version - - I forgot to mention it
sjwebb90
I happen to have a Neck & Bridge VH11 still boxed. Reading the BKP card it states the following:
Bridge 8.9K
Neck   8.2K
Cheers
SJ
