Author Topic: Boss OD-1  (Read 13324 times)
Boss OD-1
« on: November 25, 2009, 12:42:07 PM »
http://www.youtube.com/watch?v=W1fk1hO-X7s
I doubt its worth the £100+ these go for on the bay, but I must admit I'm quite curious. Not many pedals advertise themselves as an OD-1 clone. Anyone with any experience?
Re: Boss OD-1
« Reply #1 on: November 25, 2009, 01:02:22 PM »
Doing some digging. Theres two version apparently - naturally the first one is rarer, more valuable and sounding better ;)
Re: Boss OD-1
« Reply #2 on: November 25, 2009, 04:54:33 PM »
Is that the right clip gwEm?
Really only showed off his Marshall amp  - couldn't se any discussion of the pedal
I rather liked the solo tone on this clip
http://www.youtube.com/watch?v=9MCRDlUAhcA
Same again - more gain
http://www.youtube.com/watch?v=B--WF1pPyvY
Pedal apparently based on a OD1 without the buffer (hardwire bypass instead) but quite expensive
Tasty playing too!
Re: Boss OD-1
« Reply #3 on: November 25, 2009, 05:24:29 PM »
Are you researching Jake's gear gwEm?
I think with a few tweaks of the RC booster you could get quite close (would probably feel a bit more hifi)
Re: Boss OD-1
« Reply #4 on: November 25, 2009, 05:48:27 PM »
Have I missed something ?
That was like a huge leap there Will.....unless I missed a clue
EDIT: Ah - just looked at what are we listening to......makes a bit more sense now
« Last Edit: November 25, 2009, 05:53:55 PM by FELINEGUITARS »
Re: Boss OD-1
« Reply #5 on: November 25, 2009, 06:26:08 PM »
You got me Will ;)
Feline: it seems like you noticed, but the clip I posted was boosted with an OD-1
HTH seems an OD-1 fan from some forum searches, perhaps he'll join us in a moment :)
I like different pedals on my Marshall, but none really get that hair tone.. GE-7, crunchbox and phil hilbourne treble booster are my favourites on my 2204. GE-7 comes the closest, and my SD-1 before I modded it.
« Last Edit: November 25, 2009, 06:30:47 PM by gwEm »
Re: Boss OD-1
« Reply #6 on: November 26, 2009, 08:39:42 PM »
You got me Will ;)
the OD-1 is great at boosting a Marshall, I've modded an SD-1 to OD-1 specs and really should get on the case of offering this up at some point.  I might end up writing up a 'how to' and selling the mod as a kit.
murraymurray
Re: Boss OD-1
« Reply #7 on: November 26, 2009, 09:57:22 PM »
The dude who recorded our EP had an OD1, sounded awesome through a ceriatone 2204 clone and EV12L speakers. We ended up doing both rhythm tracks with it just using different guitars.
for some 80s metal style clips, a coupla our tracks using it are up at www.myspace.com/gaywyre
leads were done through a 5150
Im quite surporsed boss doesnt still make them, they seem to go for quite big money on ebay.
Re: Boss OD-1
« Reply #8 on: November 27, 2009, 12:24:14 AM »
Just compared the SD-1 and OD-1 schematics. The dual op-amp version of the OD-1 is very similar to the SD-1 indeed.
« Last Edit: November 27, 2009, 01:06:10 AM by gwEm »
JDC
Re: Boss OD-1
« Reply #9 on: November 27, 2009, 12:09:44 PM »
what's the difference between them? isn't the OD1 basically an asymmetric tubescreamer? I might be thinking of something else
Re: Boss OD-1
« Reply #10 on: November 27, 2009, 03:34:45 PM »
both the SD-1 and OD-1 could be described a asymmetric tube screamers. Obviously the OD-1 has no tone control. There are some differences in component values, and the second gain stage is configured as inverting rather than non-inverting.
if you're feeling cheap-arse, you can buy a single resistor and a capacitor and move some components and wires around to perform the conversion.
edit: obviously, while you're in there, you might want to perform other mods
« Last Edit: November 27, 2009, 03:41:56 PM by gwEm »
Re: Boss OD-1
« Reply #11 on: November 28, 2009, 02:15:30 PM »
on Friday ran out at lunchtime to buy a new SD-1, on my way home brought the components for the mods to OD-1 specs.
few hours ago I tried the stock SD-1.. i still quite like the SD-1 in standard spec, even if its a bit meh.
so just finished modded it to the later dual opamp OD-1 specs. sounds really really good. colours the sound hugely - very bright. changing the EQs on my 2204 to suit, the most amazing 80s metal tone comes out. cleans up well too.
found some circuit tweaks on the net to make it closer to the original quad op-amp version, which I'll now try. will report back
Re: Boss OD-1
« Reply #12 on: November 28, 2009, 03:43:10 PM »
the brightness is alot more manageable with the capacitor changes to bring it closer to the quad version specs. The pedal is a bit less fun though.
i'm never sure if changing audio path electrolytics is a good mod. anyway, i changed them out... could this be the source of the reduced fun?
CaptainDesslock
Re: Boss OD-1
« Reply #13 on: November 28, 2009, 04:02:23 PM »
First thing that came to mind was Ibanez's "hand wired" tubescreamer that chalks in at $300
http://guitars.musiciansfriend.com/product/Ibanez-TS808HW-Tube-Screamer-Overdrive-Guitar-Effects-Pedal?sku=620649
errrr...correction; $350  :?
Rise above the crowds
Wade through toxic clouds
Breach the outer sphere
The edge of all our fears
Oli
Re: Boss OD-1
« Reply #14 on: November 28, 2009, 04:45:37 PM »
Sounds like I may have to keep my eye out for one of these... bright... 80s... cleans up well... where's the downside?! :)
