Author Topic: Orange Not Cutting The Mustard...  (Read 5036 times)
Re: Orange Not Cutting The Mustard...
« Reply #15 on: January 15, 2010, 12:17:41 PM »
^ cheers, Brian - I was gonna keep hold of it...
I've been looking at the Egnater stuff, which looks pretty interesting.  I like the look of the modular amps, but it looks like they only come in rack format these days.
« Reply #16 on: January 15, 2010, 12:21:35 PM »
Egnater really is the way to go I think.
Jon @ Feline can give you every detail you need to know and he owns about three touring rigs worth of Randall/Egnator gear.
I'm sure Randall do a twin module combo which would suit you.
« Reply #17 on: January 16, 2010, 11:38:53 PM »
No - the Egnaters come in head and combo form as well
I choose the rack versions because I am greedy and want 8 channels of goodness and because then I can choose what power amp and how much output I use
MJW made me a great mono power amp for home use -10w that is plenty loud enough to annoy the neighbours but you could use anything from a Mesa or Marshall 20w per side to a huge 100w+ per side depending upon your needs
Look out for the new E2 amp expander/preamp that could be used with your Orange if it has an FX loop and will allow another 4 channels (2 modules)
« Reply #18 on: January 17, 2010, 10:22:59 AM »
All good stuff, chaps - I think that the Engater stuff (not just the modular amps, the whole range) is well and truely on my radar.
However, I have just re-valved my Orange, and I've managed to squeeze something a little special out of it - I put E34Ls in instead of EL34s, and it sounds amazing - very Fendery.
The only thing it lacks is a clipping section, but a nice pedal board helps that somewhat...
Still like the Egnater stuff though...
Pete24v
« Reply #19 on: January 18, 2010, 08:39:06 AM »
Or possibly an MJW Roadstar 36 tweaked to have a fendery vibe with 6V6's.
that would be my advice.
Herbie the Rad Dorklift
    • Band
« Reply #20 on: January 22, 2010, 10:44:40 AM »
Unless you're playing modern metal I'd always recommend an MJW of some kind.
jsteele1408
« Reply #21 on: January 23, 2010, 12:27:47 AM »
Vox is great for bright/sparkly. I used to play mainly classic rock, but always went for that real bright edge instead of the darker tones you'd usually find. And I always used Vox amps. There was a Vox 2x12 I was about.. |---| <-- That close to buying before I made my permanent switch to Prog/Metal. I believe it was a Custom Classic 30w.
Even my 15w Extreme Lead Vox amp is pretty bright and they tried to market that toward Metal/Hard Rock players.
