Main Menu
Intonation
Started by lepersmeesa, November 22, 2005, 11:34:52 AM
lepersmeesa
Hey, on my Ibanez RGT2020 i have pushed forward the saddle all the way it can go and my high E is still flat. Im using 52s-10s tuned DADGBE. If anyone can shed any light, that im using too thick strings etc, it would be much appreciated.
I am Ted Theodore Logan...
www.myspace.com/thesafetyfire
Skybone
I'd say pull the saddle back as far it can go, then start all over again. Only move the saddle say a half turn of the screw (use your screwdriver/allen key as a guide), retune & check, keep going until you're reasonable happy with the intonation.
Good luck!
Bibble.
Drac
High action at the nut,high action in general, too much relief, aftermarket parts/screws/nut improperly fitted, improper bridge/nut placement , and tremolo trauma can all be culprits...
  -Choose the tuning you use most,  your favorite strings, and try and check all of the above.Measure from the nut, to the 12th fret-should be "exactly" half the scale length-again from 12th fret to the bridge-
For tuning to D ( not so dramatic of a drop), you should still be "in the zone" to intonate- not more than an eighth/three-eighths/quarter inch from  the scale-( ok, maybe more, but not maxxed out in either direction)
  If the precise  scale length at the bridge from the 12th means all your saddles are maxed out forward, or back, then you might consider moving the whole bridge-Do you want to do that?
  Get a second/third opinion from pros: have it measured, and  and if things aren't right, or the tech can't  please you, don't go any further with this-
Tune it back to E and sell it to someone as it is.
-If it does check out, have it setup, and proved to you when you pick it up, and before you pay-If it sounds wrong, you are in a position to have it fixed in front of you, and hopefully will be rocking happily ever after...
Good luck from Drac
"If common sense is so common, where the hell is it?"
HJM
Change string brand - they all intonate slightly differently!
Also, check that the bolt holding down the saddle is in the hole furthest forward on the Floyd, there's usually two or three to choose from.
lepersmeesa
cheers dudes. when i get a chance ill sit down and try it out.
cheers again.
