Author Topic: LP bridge PU sounds weak  (Read 20099 times)
Re: LP bridge PU sounds weak
« Reply #15 on: March 12, 2010, 10:37:17 PM »
May have nothing to do with the problem but on the kill switch the "bare wire" coming off the top contact looks very close to the centre contact of the switch (red wire). Is it shorting out?
But that would affect both pickups
1) the earth braiding looks like it could do with a bit more solder
2) Take the 3 way switch out and blow air through the contacts  whilst moving the toggle in case dust is stopping the contact ( or use servisol contact cleaner)
3) Failing that it could be a duff pot
I do feel that guitars like this could do with better shielding in the cavities
hermetico
« Reply #16 on: March 12, 2010, 11:22:10 PM »
To me, the soldering work looks very neat. The only thing I don't like is that cap.
The legs of that cap aren't isolated.
When closing the tap, you can accidentally move that cap and shortcut some hot lug near.
Additionally, if some leg is in the hot path, and that leg touches the cavity, you are also shorting there.
Independently of if this is your current issue or not, I suggest you to isolate those legs, with electrical tape or with some heatshink tube (neatest).
Check this kind of potential shorts. I usually try to isolate every hot lug, to avoid any accidental shortcut.
I had experience with guitars that worked fine just until the moment that I closed the tap. When mounting the tap, I had to push some wires inside and, some accidentally shortcutted some parts of the wiring.
Just my 2 cts.
Can you please attach some pictures of the rest of the wiring?
Better than this, can you please attach some sketch where you show how every wire is actually connected?
I miss something there, the link between volume and tone pots, also, I don't see very clear how did you wired the killing switch. Usually, kill switches have connected the jack's hot and ground, as well as the hot output of the circuit, but It seems to me as if it was linked to the tone pot, instead to the pickup's selector.
A diagram, even hand-made would be very helpful to catch the bug.
« Last Edit: March 12, 2010, 11:31:41 PM by hermetico »
« Reply #17 on: March 13, 2010, 12:56:22 AM »
On a typical guitar with 2 pickups , 2 vols and one tone such as a flying V or explorer the output from the switch goes first to the tone pot and then out to the jack.
All they have done with the kill switch is divert the wire to that switch first, allowing the signal to be killed off or directed back to the tone pot and subsequently the output
I don't disagree with having insulation on the capacitor legs but it is nowhere near the signal path for the bridge pickup, so is unlikely to be the culprit here.
Reading carefully what Searcher has said - the neck pickup works 100% fine  and doesn't cut out so we needn't concern ourselves with the bit of the circuit that is common to both pickups as it can't be at fault or else the neck pickup would suffer like the bridge one is ( so ignore the tone pot, the kill switch  and the jack
The problem exists somewhere on the signal path from the output wire of the bridge pickup via the bridge volume control through to the switch.
You can eliminate components one by one and get to the source of the problem
1)Ensure that the bridge pickup is well connected to the ground - re-solder it to the pot - if the problem goes away it was just that the pickup wasn't earthed properly........then try wiring the hot from the bridge pickup to the input to the tone control (Where the white wire goes) - this will show whether the pickup is working ok.
2)If pickup is ok connect the hot wire of the bridge pickup directly to the uppermost tag of the switch (as seen in the picture) - you are bypassing the volume pot by doing this . If your pickup is still louder than it was before the pot or it's connections are to blame.
3) if it is still quiet the problem more than likely is the switch -
hermetico
« Reply #18 on: March 13, 2010, 09:55:24 AM »
Thank you, I thought it was a 2 vols + 2 tone guitar. Now it's clear.
Quote
As I said, not necesarelly his current issue but, something that could be an issue in future, specially when braided conductors are all around. I just wanted to point out that could have other potentially risky points there.
By example, that big drop of solder so close to the pot's lugs. It could put in contact the grounded lug with th
e hot lug. A frontal view of the lugs should clarify that.
One more thing to check is what is unseen. The fabric of the bridge pickup could be peeled off because of the heat produced while soldering the grounds to this pot, so, the bridge's hot could be in contact with the yellow ground visible under this wire...
So, check also for peel off wires, free strands or any other suspicious thing also in the unseen side.
Quote
If everything seems to be well grounded and the wiring seems correct then, I bet for that suspicious drop of solder or a fried pot (bridge's volume pot). Those big drops of solder can  result in a very overheaten pot.
I'd first try the pickup hot directly to the pickup' selector, to overpass the volume pot.
« Last Edit: March 13, 2010, 10:16:01 AM by hermetico »
Searcher
« Reply #19 on: March 14, 2010, 06:00:12 AM »
Hey, thanks so much for the detailed responses!  I printed this thread out for reference and we messed with it today and now it works - yay!  :)  Thank God for that.  I'm so sick of having the touch of death for electronic stuff.  It drives me nuts.
Quote from: Sifu Ben
hermetico
« Reply #20 on: March 14, 2010, 10:17:43 AM »
You are a bad boy, dude. :x
WHAT WAS THE ISSUE, THEN? :tfrag:
« Reply #21 on: March 14, 2010, 11:50:40 AM »
Congratulations on getting sorted and glad we could help
That's one of the many good things about a forum like this........
We are all curious now as to what fixed the issue in the wiring - if you know which step cured the issue.
Personally speaking - I would have liked to have seen more screening in that guitar - but I guess Gibson dont feel the need for it.
I am a believer in good screening (as well as good wiring) to keep noise to a minimum
I will be doing a feature on this issue soon - so keep an eye out for it
hermetico
« Reply #22 on: March 14, 2010, 03:35:50 PM »
EYE :gne:
Searcher
« Reply #23 on: March 15, 2010, 05:02:12 PM »
Yeah, this guitar is totally unshielded and hardly finished at all.  I think it's Gibson's answer to their quality control issues: "Yeah, umm, it's meant to be that way . . . it's a feature!"  The guitar feels really nice to play, though.  Something about the rough finish appeals to me, too, in a semi-masochistic way.  No splinters yet.   :lol:
As for the pickup I think something just wasn't sitting right.  We cleaned up and resoldered the main two joints on the pot.  It has a really big sound!  (I have the pickup sitting closer to the strings now, too).  I dragged out my Strat with a Sinner in the bridge and now that sounds thin and weak by comparison.  :D
« Reply #24 on: March 15, 2010, 06:32:33 PM »
I like the way there are mahogany "whiskers" all over the routing in the control cavity.  They made no effort at all, did they?  :lol:
Searcher
« Reply #25 on: March 19, 2010, 08:57:40 PM »
Not so you'd notice.   :|
Actually, I'm having more troubles with the thing.  The truss rod doesn't work.  And as soon as you look at the guitar it loses its tuning.  I think this will be the last time I buy a guitar without playing it first!
So, err, anyone wanna buy a really nice Gary Moore Les Paul?   :P  The tuning is meant to be this way, honest.
« Last Edit: March 19, 2010, 09:00:01 PM by Searcher »
