Proof (if proof were needed) of why BKP rocks - NPD! (Clips added!)
Started by Nolly, May 13, 2010, 12:05:59 PM
Nolly
Quote from: fr33man1 on May 14, 2010, 09:30:41 AMBut Im still curious, you always have very middy p'ups, guitars, and some amps simulation on axe FX like 5150 is also middy.
Aren't those guitars too bright on gigs or rehearsals ?? Im fond of the KSE alike tone you get out of the swamp ash ones but Im still wondering  :lol:.
Nah dude, never had a problem with over-brightness. The RY is also considerably darker in the top end than the old CS I had in there, so it's even less of an issue.
Quote from: MDV on May 14, 2010, 04:53:59 PM
I'm quite surprised by how aggressive it is.
Remember, as I'm sure you do, that your double screw pole version will inantely have more bass, and that the general ballance between low and high end can be tuned (clumsily) for each string with the relative height of the two screws; raise the neck-wards one for more low end and vice versa. I suspect this is why you got it DSP (its why I used to get all my bridges DSP), but just making sure - you may be able to find screw heights that let you use the same settings for all/both guitars.
Yep, me too. The RY is giving me literally the best metal tone I've had, I'm absolutely smitten.
And yeah, I order DSP for that very reason :)
Quote from: bengalstar on May 14, 2010, 06:35:30 PM
what a gorgeous beast.  (the cat is pretty, too.)
Nolly, just wondering what you think of the Nailbomb.  I know Misha favors the Cold Sweat as well, those clips sound pretty fantastic to me (forgive me, what rig are you playing through?)   I understand the lower output is to maximize the articulation and definition.
Just got a Nailbomb put in a strat with an all maple neck, and it helped to "organi-cize" the overall brightness of the guitar.
Just seems like there are so many options with woods and such.  The nailbomb sounds great to me (in that guitar)...what would you recommend for Mahogany/ Maple/Rosewood?
you are a fantastic player, btw, your SiKth youtube clips are just stellar! (as are any clips you post, for that matter).
Hey dude, thanks, glad you enjoy the vids/clips :) I'm using a Fractal Audio Axe-FX for the tones.
I love the Nailbomb, it's a great pickup! The original alnico version is very organic and open, while the ceramic is grindy and saturated, with lovely top end bite and tightness.
Misha is using the Cold Sweat in a couple of his guitars (he got those in his Blackmachines on mine and Doug's recommendation), but he's experimenting with a few different ones. I'm definitely going to get him to try the Rebel Yell, and I know he's keen to check out the Aftermath too.
For your guitar, if the stereotypes are true you should have a fairly open choice to make, you just have to decide on the voicing you want. I can highly recommend the RY as an awesome pickup to try, but you could hardly go wrong with any of the range.
bengalstar
Duly noted, now you got me curious about the RY!  (as well as a C-Bomb...and a C-Pig......jeez...good thing I have enough guitars to put all these pickups in  :P)
How does the RY compare to an A-Bomb, in terms of YOUR ears?   Tonally what has been working for me (up to this point, at least) was Duncan SH-13's (Dimebuckers) in a couple of Ibanez S series (Mahogany/Maple/Rosewood)....
I went with the A-Bomb in the maplenecked strat to try and get a similar thing, and it appears to have worked (albeit I am smitten with the Bomb, it's way more articulate than the Dime).  I'm using Line 6 stuff, I have a Vetta HD with the 2.5 software (the Powerball model is my fave) , and an XT Pro (funny how the models don't sound anything like each other...that really pissed me off...the PBall in the Vetta is way better sounding than the XT).
I also got a Diver for another maple necked guitar, it sounds good with some patches, but has a little less output than I thought it would.  I'll leave it for now, but will most likely get another A-Bomb for that guitar.
Would you suggest trying a RY in one of my Ibanez's?
You are all $%&#ed and overrated, I think I'm going to be sick, and it's your fault.
Ribboz
C-pig, C-Diver, Holydiver, Miracle man, Sinner, Trilogy, Slowhand.
Nolly
Quote from: bengalstar on May 18, 2010, 08:05:06 PM
Sorry dude, I never saw this!
I've not directly compared the RY and A-pig in the same guitar, but my expectation would be that the A-pig was significantly darker and more saturated. The RY seems tighter and clearer, and has more upper-end harmonic interest to my ears.
