Author Topic: I hate being into guitars some times....  (Read 13608 times)
Re: I hate being into guitars some times....
« Reply #15 on: July 01, 2010, 05:00:28 PM »
How about a proper guitar?
Couldn't resist :)
« Reply #16 on: July 01, 2010, 05:17:00 PM »
Couldn't resist :)
 :D
I was waiting for that!
« Reply #17 on: July 01, 2010, 05:26:41 PM »
One thing that may more of a dfifference than you'd expect is the tone capacitor (as well as losing the treble bleed)
Swap it out for an oil and paper one - will make a nice difference
« Reply #18 on: July 01, 2010, 05:44:24 PM »
Ian, "the one" had these BG 1400, right? I think it's a nice idea to have it again... if it worked once, it's supposed it will again...
« Reply #19 on: July 01, 2010, 06:24:53 PM »
+1
I actually came back in here to post this :lol:
Like I said earlier, my Baja has PIO at the moment, and with my Blackguard Flat 50s, it kinda mellows things out a bit in a way I'm not sure I want...
But thinking about it, the same effect on the Baja's original pups might be a good thing for chaps like you and me, Ian (chaps who find the original pups a bit wanting in the "body department") :D
« Reply #20 on: July 01, 2010, 06:49:59 PM »
I haven't bothered to read any threads about paper in oil capacitors - where are you guys buying them?
« Reply #21 on: July 01, 2010, 07:05:36 PM »
Cheers Philly - that was my next question!
« Reply #22 on: July 01, 2010, 09:12:15 PM »
You've got the S1 switch on the Baja Ian, so if you switch to CTS pots you'll lose that option.  If you want a more traditional Tele switching arrangement, you'd be better off selling the Baja and getting something else?
That Deluxe has a TRUCKLOAD of gain, so try setting the Power Scaling much lower to bring in the power amp distortion.  It works a treat!
I got some old PIO caps from AxesRUs as they were quite cheap.  I've still got some 0.022s if you want one Ian?  Let me know  :)
« Reply #23 on: July 01, 2010, 09:18:01 PM »
Get them from ME! (you can often take it as given that if I'm hot about a product like this that I will stock it and fit it in my own guitars too)
Or ring Tim if you must ..............
The Baja tele is a good guitar - if you were chopping stuff around on it I would just swap out the whole wiring harness for a straightforward 2 x 250k ohm CTS and an oil and paper cap and a switch - that way you can easily replace the old harness if you choose to sell later
« Last Edit: July 01, 2010, 09:20:01 PM by FELINEGUITARS »
« Reply #24 on: July 01, 2010, 10:22:16 PM »
I can see your point but I'm really not keen on losing the deluxe (I can't afford a new amp and keep the deluxe). I think the issue is more to do with the pickups though as other guitars I have played through the deluxe have sounded great. I do have a bad monkey that I use occasionally and whilst it does give more gain it still doesn't sound how I would like it to.
fair enough, if you're sure it's the guitar, then that's fair enough.
bear in mind that removing the treble bleed isn't necessarily a panacea. IME, while guitars with treble bleeds can sound thin with the volume down, guitars without them sound way too muddy/dark etc. :lol: If i could be arsed, I'd try a whole bunch of different options for all the ways you can wire a treble bleed (you can put a resistor in there too, various different values of caps and/or resistor, wiring the resistor in series/parallel, i think, etc. etc.) to see how close to perfect you can get. i think there's some info on it on the duncan site, but i could be wrong.
or even put one on a push-pull pot, so you can select whether it's in the circuit or not (that's what i'd do if i weren't lazy- i like the extra sparkle for when i'm rolling back to clean, but like the extra darkness for when i'm rolling back to a bit less overdriven, but still overdriven).
« Last Edit: July 01, 2010, 10:24:19 PM by dave_mc »
« Reply #25 on: July 02, 2010, 12:04:02 AM »
I hate being addicted to biking. My bikes always got something wrong with it - now it needs a new rear wheel as the current one's nackered. At least £90 for a new one. Bloody money drain - worse than guitar at the minute!
« Reply #26 on: July 02, 2010, 09:06:28 AM »
Quick question Jonathan:
I was looking at swapping the pots for CTS a few months back (I had some spare ones from you at the time) - but they won't go through the metal plate... I put the idea on the back-burner, and used the pots for something else.
How would you usually get round that? Is it a "drill the wholes bigger"? Or "get a different plate"?
Or by "harness" did you mean the plate as well?
« Reply #27 on: July 02, 2010, 09:59:43 AM »
Is that on the Baja or one of your MIJs?  I thought the MIM Teles had US pots already.
It's dead easy to make the holes bigger - a 10mm bit is quick but leaves them a bit oversized, so I use my countersinking bit and work from both sides of the plate, to get the holes just right for a snug fit.
« Reply #28 on: July 02, 2010, 11:03:06 AM »
Either way
« Reply #29 on: July 02, 2010, 11:09:58 AM »
great tip with the countersink bit from Philly - I like that one :)
i drilled out the plate on my Cyclone - no regrets there
