Author Topic: I just found an electro harmonix delay in a skip!  (Read 5380 times)
Re: I just found an electro harmonix delay in a skip!
« Reply #15 on: August 06, 2010, 03:44:46 PM »
I've got an old Little Big Muff from the 70's too.
Does anyone know what sort of power input these are? Like, voltage and polarity?
Hi Johnny, I believe they are all 9v dc.  As for polarity,  can you look at the battery connection and work it out from that (or let gwEm look at it  :) )
roland_rat
« Reply #16 on: August 06, 2010, 04:21:23 PM »
I have got one at home that does not see much action these days.  If I remember right it had a two pin plug on mine which plugs into a transformer.  Very nice analog delay. I only stoppped using mine  has the transformer has a annoying hum. Guess I really should get another transformer to plug into.  I will have a look when I get home just what voltage it uses.
Anyway I hope you get yours working.
« Reply #17 on: August 07, 2010, 06:01:02 AM »
I had a look inside it last week when I found it. It has no battery inside, just a small jack plug socket which is the same as my little big muff. The LBM has a battery so I could work it out from that. Good idea Phil, thanks.  :D
roland_rat
« Reply #18 on: August 07, 2010, 01:03:30 PM »
I checked this morning and mine has a cable connected in the left hand corner (near the on off  power switch).  It has a three pin plug on the end. All be it a rather different one than our the usual  3 plugs we have in the uk.  This connects to an AC to AC convertor which has a output of AC 110V.
« Reply #19 on: October 23, 2011, 05:20:09 PM »
I got an old Electro Harmonix power supply on Ebay for £4 and this old gem works fine! I think they're from around 1976. It sounds pretty good, all the controls still work ok.
« Reply #20 on: October 23, 2011, 06:06:13 PM »
Nice one, they sound good. Eric Johnson uses them.
choucas09
« Reply #21 on: October 23, 2011, 08:16:29 PM »
So you got an up and running EH delay for 4 quid. Life's pretty good sometimes.
juansolo
    • Juansolo's Gnomepage
« Reply #22 on: October 23, 2011, 08:50:17 PM »
Cool find!
