Author Topic: Neck pickup for my guitar  (Read 4658 times)
gordiji
Re: Neck pickup for my guitar
« Reply #15 on: August 10, 2010, 07:52:29 PM »
the mule in the clip is A2 , it says this in the comments below. also i think the guy has his guitar coil tapped so attention is needed in putting a sound to a pup (you may be thinking hbucker when it's being played as a single coil)
i watched the vid a while back and it's a lovely sound.
don't forget if you order something that doesn't end up being what you imagined you can send it back and swap it.
good luck
Drew186
« Reply #16 on: August 10, 2010, 08:03:45 PM »
Awesome thanks. I didn't even realize that, that particular mule was using the same magnet as the SM does. I figured it had the stock IV. That makes me lean back towards the SM a bit.
« Reply #17 on: August 10, 2010, 08:54:59 PM »
well the a2 stormy monday is sweet clean.. but as denim'n'leather once put it - its a bit loosey goosey medium to high gain.
twinfan likes to hype the a4 stormy monday - might be worth asking tim about.
i'd personally go for stock a4 mules - they are voiced quite neutrally
