can't get floyd rose to stay in tune (UPDATE)
Started by HTH AMPS, August 14, 2010, 01:46:31 PM
Quote from: FELINEGUITARS on August 14, 2010, 07:20:29 PM
try :
Remove middle spring and tighten spring claw up to restore balance
this will put remaining two springs under greater tension (even in neutral/rest position)
This may remove odd behaviour
will give that a try, cheers J.
as for the Floyd, its likely a Korean one as these BC Rich's are made in Korea.  are the real-deal original Floyds a straight swap? it is even worth doing this?
Stevepage
They are direct drop ins so that shouldn't be a problem.
However if the problem keeps persisting and you really want to keep the guitar then I'd go for an original floyd rose. Even used they're usually in good condition.
Quote from: HTH AMPS on August 14, 2010, 08:42:06 PM
try :
the 'real' ones are much better... but i count the modern 'ping' floyds as real ones personally.
i changed a dirty knock-off floyd to an OFR one and the difference was night and day, and tonally especially!
OFRs are around £150.00 though (ouch!!!!).
Might keep my eye out for an old 80s/90s cheapy metal axe with an OFR and put the Korean one on it to resell.
Stevepage
Well according to John Suhr, Original Floyd Roses aren't what they used to be. He changed to Gotoh trems as their quality is a lot better. He found that he had to work on every Original Floyd rose he got, something to do with shoddy saddles I think.
Considering the high quality of Suhr guitars I'd be confident with using a Gotoh and they're a bit cheaper.
thanks for that - will check Gotoh out.
also spoke to my local guitar guy, he reckons its a common fault and the trem posts going into the body are usually to blame.
gonna take it over to him to checkout.
the gotoh one is very nice, but (if i remember correctly) the studs are marginally larger than the OFR ones, so if you want to use the gotoh studs you'll probably have to drill (i assume, i know nothing about DIY :lol: ).
Quote from: Stevepage on August 15, 2010, 11:57:22 AM
That does fit in quite conveniently with the fact that all the other bridges Suhr use are Gotoh as well....  :wink:  :P
It may well be true though.  Floyds are anathema to me, so I'll never find out, but cynicism apart, I'm a big fan of Gotoh hardware in general.
I'm not a FR abuser (I tend to block them) but the gotoh is very well engineered; at least as good as OFRs and schallers (so basically, at least as good as schaller, since they make OFRs anyway).
Ribboz
You prolly could send it to Feline for a setup? I think he does that.
I've heard decent stuff about his work.
C-pig, C-Diver, Holydiver, Miracle man, Sinner, Trilogy, Slowhand.
Quote from: HTH AMPS on August 15, 2010, 11:25:52 AM
OFRs are actually closer to £250 - I know - I've just ordered one for a custom build through the official importer
I suspect that there are some "grey imports" on ebay although the real ones seem to be £175+
I had the same issue on my Axis. Turned out the blades/studs had some nicks, that's the death verdict.
So I got a new Gotoh from WDMusic, installed it carefully and I am stressfree since. Only thing that's a bit of a headache is that the D-Tuna only leaves VERY LITTLE fine tuning on the low E. This works much better with an OFR.
Ribboz
Quote from: FELINEGUITARS on August 16, 2010, 02:37:38 PM
Geez!! they cost a lot more in Brit. :\
