Author Topic: Fulltone Fat Boost  (Read 15111 times)
Re: Fulltone Fat Boost
« Reply #30 on: September 09, 2010, 05:55:56 PM »
Cheers Andy - trying to move a few things on at the moment and may well take the plunge. I'll be aiming to keep all of the switching options the Baja has - as a technical dunce what do I need to ask for when ordering? I'm assuming the both pickups in series option means I need to ask for something different on the wiring?
« Reply #31 on: September 09, 2010, 06:19:26 PM »
Yep  :)
You need a separate ground wire from the neck pickup cover.  Tim and the boys will know what you need if you say you need this as you'll be using a 4-way switch.
« Reply #32 on: September 09, 2010, 06:33:30 PM »
Cheers Dave  :D
Hoping I can get it sorted in time for the meet.
« Reply #33 on: September 09, 2010, 07:52:05 PM »
Yep, exactly what the TF-man sez :D
I kept all the same hardware, including the S1 (don't use it though). I tell a lie, I snipped off the treble-bleed capacitor I found across the volume - that won't help on the thin/weedy front. Try removing that now if you haven't already. Not sure where it will get you though - I've since tried the Baja pups in another tele without a bleed, and I replaced them with Blackguards too!
Soldering onto the S1 was a little more fiddly than standard, but if I can do it, anyone can! :lol:
Good luck. Hopefully you'll get the same thing as I did with the BGs - I went from "I just can't get into this tele thing" to "Oh wow, what an instrument" in the space of just a couple of hours (and more teles in a couple of months :roll:)
« Reply #34 on: September 09, 2010, 08:40:47 PM »
Cheers - I think the treble bleed has been mentioned to me before. I must have forgotten though as it is still on there!
I do love tele's - I was always a strat man but am getting more and more into the tele now. I've previously owned a few great teles and am now on my 3rd. I'm determined to hang on to this one as it feels comfortable for me and has quite a nice acoustic sound to it.
« Last Edit: September 09, 2010, 08:47:23 PM by Ian Price »
« Reply #35 on: September 10, 2010, 03:22:20 PM »
I like the EP a lot.
The SHO is I think what was in my Box Of Rock - really liked that one, too. I think the SHO is probably a bit harder and more transparent, whereas the EP has more spaciousness and mojo if you wish.
I don't like the OCD as a booster.
The RC Booster is very nice, too, especially if you wanna add chime and sustain to clean and crunch tones.
« Reply #36 on: September 11, 2010, 12:57:35 AM »
I use a Toadworks double boost. You can mix fat and clean-boost (two knobs, third knob is level). It works perfect and sounds great. Unfortunately they are out of production, but you can find used ones. I see Fulltone Fatboosts often on Ebay and that's not really a good sign.
