Author Topic: Speaker suggestions  (Read 6817 times)
Re: Speaker suggestions
« Reply #15 on: September 30, 2010, 11:55:57 PM »
You're missing the point mate  ;)
A V30 and a G12H in the same cab can only handle twice the power of the lowest wattage speaker.  A G12H is rated at 30w, therefore the cab can handle 60w.......
« Reply #16 on: October 01, 2010, 12:29:38 AM »
Ok, you could be right, then maybe two V30's.
Alex
« Reply #17 on: October 01, 2010, 10:57:43 AM »
The V30 has an excellent resale value, so if you don't like it...  :shock:
Personally I've been a loyal Eminence fan; I used to have the V30 16 ohm and the T75 8 & 16 Ohm, but nowadays I use Eminence mostly.
I've got the Krank Legend V12, which I hear is a bit different from the standard Eminence Legend V12. It's a great all around speaker, maybe a bit much bass.
I've used the E. Governor a lot, very aggressive and powerful, cuts through the mix great. I also have a E. Black Powder, supertight, great for superclean sounds or superheavy downtuned ones. Not much in between. And finally an E. Cannabis Rex, which is kind of similar to a Weber speaker (I was told, aka hearsay). Big round sound, very warm, very full, great for making a harsh amp sound big and warm.
Brow
« Reply #18 on: October 01, 2010, 12:51:44 PM »
Thanks for the info!
I don't really know of many people that use Eminence, so thanks for the input and other point of view! :)
The list of possible speakers to look into is now getting quite long................  :lol:
« Reply #19 on: October 01, 2010, 02:01:07 PM »
That doesnt seem right to me, when the power is distributed between 2 - 4 speakers. It would, I guess, be distributed between the speakers according to their relative impedences, if theres any rule to it, and just equally if not. Practically speaking, since impedences are rarely (at least)/never (that I know of) mixed the power will be split evenly between them.
« Reply #20 on: October 01, 2010, 02:07:00 PM »
i was wondering about this.
a 4x T75 cab is rated for 300watts. even though it has 4 75watt speakers, by that rule it would only handle 150watts right?
a higher power g12h has got me gasing a bit.
martinw
  • Building Amps in the Hills.
    • http://www.mjwamps.com
« Reply #21 on: October 01, 2010, 02:44:02 PM »
Are you agreeing or not?  :)
You're right anyway in that power is distributed according to impedance, just as any other load.
Usually equally therefore, and thus limited to 2 times (or 4 times in a 4x12) the LOWEST powered speaker.
Custom Built Amps:
www.mjwamps.com
« Reply #22 on: October 01, 2010, 03:02:45 PM »
Actually, yes, that follows.
I was dissagreeing, for the record, using the same logic that should have led me to agree.
Anywho, yeah, bit distracted; last day of work ever!
« Reply #23 on: October 01, 2010, 03:13:00 PM »
see you on jeremy kyle then?
Elliot
« Reply #24 on: October 01, 2010, 04:20:33 PM »
Isn't a Classic Lead essentially a G12H30 with a kapton coil?  Or am I mixing things up.
BigB
  • Let's rock !
« Reply #25 on: October 01, 2010, 04:27:23 PM »
Then count me in too - I use an eminence legend GB 12/8 on my HRDx, was on my Blues Junior before, and it's been a major improvement in both amps. It's a kind of a greenback-like (as the name implies), with possibly tighter lows (but I'd need to compare with a real greenback in the same cab and with the same amp to make sure), and it's really not expensive.
« Reply #26 on: October 01, 2010, 04:32:09 PM »
I had to look him up - I dont own a TV, remeber, let alon e watch it in the day.
No, I took a voluntary severance deal that they offered to everyone where I work. I'll be self employed as a guitar tech and audio engineer (before any of you whine that I'm not very good at that; its a relative thing; I'm better than most in the back of beyond I live in).
If it doesnt work, then I've got good qualifications and a good CV: photovoltaics/nuclear fusion/nanoelectromechanics here I come! (stuff I specialised in at uni mainly).
Sorry for the threadjack
Carry on....speakers, etc.
jpfamps
    • http://www.jpfamps.com
« Reply #27 on: October 02, 2010, 05:59:59 PM »
Quite possible. They look to be very similar apart from the power handling. They might use different cones though.
Pete24v
« Reply #28 on: October 03, 2010, 12:26:15 PM »
A V-30 (depending on who you talk to) can handle 60 Watts or 75 Watts. They are definitely NOT 30 watt speakers-- 30 refers to the size (30cm).
A Celestion rep once told me that the V30 can handle an easy 60w, but it needs 30w to make it sound the way it was intended, hence 'Vintage 30'
« Reply #29 on: October 03, 2010, 03:39:55 PM »
the Tayden Great Brit (50w) has gotta be the one to go for in a 2x12.
