In search of a great bedroom sound
Started by Alex, October 02, 2010, 10:42:56 AM
Quote from: martinw on October 03, 2010, 01:39:59 PM
Yes, the Bimbo does use Power Scaling, "The Valve" are a licensed manufacturer.
PS is also a good option.
thanks. yeah, then that's not really the same thing as an attenuator. :)
I'm not really sure if you need, or even want, the power amp in meltdown for brootz, though...  though I guess it might let you get it turned up enough to where it starts sounding great.
Alex
I will try to POD into the amp. Basically I guess it would show me how the whole setup sounds with a modelling preamp before the Krank - it might work well.
Unfortunately I didn't have any time to pick up the guitar since Sunday :-( and now it's too late to try.
Thanks guys, I'll see what I can do.
With Full Distortion
HOW Much for the 5150 and do you have any pics?
wfd666@hotmail.com
q: p
jp
Alex
Well... tried the POD... quite sobering. The Krank sounds even with all the fizz from the low volume setting still better and the touch sensitivity/dynamics is a lot much better.  :(
Don't know exactly where to go from here now, I was already developing GAS for those new Line6 floor POD, but now...
The one thing I did notice was that my Overdrive (T-Rex Michael A Batio) into the clean channel did outclass the Pocket Pod in transparency, feel and touch. Maybe a decent stompbox into the clean channel is better?
I'm also a bit worried now what help a different amp would do. Maybe the 20Watt Krank is already about as good as it really gets for bedroom level? I'm beginning to think that MDV might be right.
marantz1300
You could try one of these.JCM900 MK111.1x12,50 watts swithable to 25 watts.With the gain turned up and the master lowerd,saturation is reached at low levels.
