First Blood -CS bridge
Started by Transcend, October 03, 2010, 04:43:00 PM
Transcend
Still gotta EQ my amp to match this guitar.
Just a quick clip to test it out.
I didnt realise the CS bridge was so bright and in a slightly bright guitar its a bit overkill so i may be changing this one out pretty soon.
CS cuts definitely, tight and bright. For this style not bad at all, you don't get lost in the mix. Not my sound though, but I don't play metal. Great demo nevertheless. Thumbs up.
Transcend
To be honest im not overly fond of this sound it was just the most manageable i could get with it i much prefer the MM its a bit more raunchy.
I'm pretty sure ill get the hand of this pickup though its requiring a great difference in EQ on the amp so with more fiddling i think i could get something that i like more. I need to play with the height a bit more too
The MM-clips I heard, show this pickup is very balanced and has a great leadtone.
gordiji
heavy stuff, not my bag but the the guitar sounds great, i don't find it bright but thick and fat.good tight playin' too.
Transcend
Quote from: gordiji on October 09, 2010, 08:24:18 PM
This is once i counteracted the Brightness.
Thanks for the comments.
With Full Distortion
Hellow man
thats a very nice clip
i liked it a lot
YOU should try a Nailbomb instead of the CS.
Transcend
I've tried the NB in many different guitars but never really got on with it which is a shame as i absolutely love the tones that other users get from them.
If you check out my newer clip ive gotten to grips with the CS now and i'm quite pleased with the sounds im getting.
Thanks again
Sounds oddly dark. Needs more cut and intensity in the high mids.
I'll check out the newer ones.
Transcend
Yeah ive found that the positioning of my amp/mic in the room just created this really dark muffled sound
Good that you pay attention to amp/cab location as well  as mic location; its very important and most people overlook it. Got any songs from after this revelation?
Transcend
Quote from: MDV on November 05, 2010, 05:54:53 PM
Just this one
http://soundcloud.com/tony-boyes/muya
well theres another but that was a very quick thrown together sketch its also on the soundcloud if you're interested.
Whenever my aftermath arrives i'll be doing a more serious recording where ill spend more than 30-45 mins recoridng & mixing lol
Also i've changed out the valves in the amp too and had a few mods done to get rid of the horrible TSLness so they should all come out far better anyway.
Sounds much better.
Guitars are still a bit low for my tastes (but plenty of people like guitars at that level), and a little phasey; have you tried isolating the cab/amp from the room (as best you can at least) to cut down on reflections making it back to the cab?
Spend a day or two playing with amp locations, shielding round the cab, reflection and absorbtion control in the room, mic placements, settings, make notes, take photos and do test recordings (make sure the notes, photos and test recordings are all properly linked up or they wont mean anything later!) and it all gets much less painfull the next time.
I never had much luck recording my TSL personally, though. Its a tricky amp; try and make it sound big and fat and it sounds muddy, its top end is woolly under more than moderate gain so its hard to get attack out of and its generally hard to manage. The best mic placement I could find was similar to what I still use: aimed at the edge of the dust cap, on axis. Sold it years ago though, shortly after I got my powerball.
Transcend
yeah i need to look into isolating it a bit more and definitely need to work on placement a lot.
I do actually have a iso cab on my shopping list for after christmas which should also keep the neighbours a bit happier (live in a flat)
I have been looking a lot at the powerball II lately and also the JVM but im really torn as i know i need an amp upgrade but really cant decide between them as i love them both even though they are completely different beasts.
Havent tried the PB2. Cant really comment. If I could only have my PB or my JVM though, I'd choose the PB without hesitation, for recording. It mics up much more easily and the tonal variation from the shear 'width' of its controls is massive. It has plenty of attack, and its particular character comes across really well at the speaker, close miced (a lot of amps can sound great in the room and get really tiny when you close mic them, and the JVM is one of them; powerballs mic up really well though, if you know how to tweak them).
Isocabs are great for tracking quiet, but they have their own sound as well. Not sure I approve of it or not. What I do is track at really low volume with a DI at all times, get the playing right and reamp later.
Another possibility is something like the palmer 03; DI that comes off the power amp, gives a load and a speaker sim. I've heard good results, but I like mics. Mics have their own sound and response and I'm loathe to lose that part of the chain, personally.
