I saw CAE launched a powersytem. Ok, nearly 300 euro.
The Dunlop CAE Power System MC-403 is the ultimate solution to powering multiple pedals. Designed through a collaboration between Bob Bradshaw and MXR's design team, the MC-403 can power many different types of pedals in the cleanest and most reliable manner possible. The MC-403 can provide multiple sources of clean power for all of your power needs, making this high performance and high quality power system perfect for studio or stage. Quiet operation is ensured with toroidal transformers that provide exceptional performance, no matter how many pedals you are powering. The MC-403 was designed for real flexibility – use it on a pedal board or rack mount it in a single rack space with an included front mount bracket. All of the multi-tap outlets are linear regulated, isolated, and protected against short circuiting. And the MC-403 is housed in a heavy-duty and rugged housing for years or studio or road use. All of this adds up to professional standards of reliability and quality power for your rig.unlop CAE MC-403 Power System You've invested a lot in your pedal board in order to fine tune your tone. The last part of the equation? How you power the pedal board. The Dunlop CAE MC-403 is the ultimate solution for powering pedals of all different varieties and power needs. A significant aspect of using pedals is powering them in the cleanest and most reliable manner possible. The Dunlop CAE MC-403 is the final piece of the tonal puzzle, providing ultra-quiet operation and maximum flexibility. Dunlop CAE MC-403 Power Supply Specifications: Input: 115V/230V~50-60Hz 100W, fuse 250V/1A E56092 or E221465 Pedal Output: AC Thru-200W Max, hardwired to Input Voltage Transformer isolated 2 (two) 9VAC's 8 (eight) 9VDC's 4 (four) 18VDC's 2 (two) 6.5-10.5VDC's (out), 10.5-15.0VDC (in) Dimensions: 43 (W) x 102 (D) x 44 (H) mm; 13.5 (W) x 4(D) x 1.75 (H) inches Weight: 2.63 kg/ 5.8 lbs (with front) panel installed
