Brown Sugar vs Boss
Started by braintheory, November 06, 2010, 09:48:05 PM
braintheory
which of the bk tele pu's has the most grind?
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Mesa/Boogie Mark III Coliseum
Mesa/Boogie Mark IIC+
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Wizard Modern Classic
Piledriver, but that pickup is far away from the classic tele sound. I'd stick to BG50's.
braintheory
I do want a traditional sounding tele, but I also want some grind and aggression.  Also, to me a traditional tele has a unique metallic crisp sound in the bridge position that I have never heard in other guitars except teles.  Will the country boys and bg's have this signature metallic quality in the bridge?  In the clips I heard these two pickups did not have it at all.  They both sounded too warm and refined and almost stratty.  To me a traditional tele is rawer and more raunchy.  However, the clip I heard of the Brown Sugar had a little bit of that metallic bite, but not as much as would want and still did not have that rawness.
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
BigB
Quote from: braintheory on December 05, 2010, 06:54:34 AM
The BGF50s bridge on my Tele doesn't sound "stratty" at all - it's all about grind and raw power, even on a rosewood/alder '62 RI. Now it doesn't have any of the ice-pick syndrom of the original pup, but this is not something I would complain about ;)
The neck (old BGF50s wind - think it's now the 52 set neck AFAICT) is indeed kinda stratty but I like it. YMMV.
Nolly
If it's absolute textbook Tele you want, try the '55 Stagger set.
If you want traditional Tele with extra grind and power go for the Brown Sugars.
If you want a ferocious treble response, go for the '68 Stagger.
If your Tele doesn't sound like a Tele with those sets, it won't be the fault of the pickups ;)
braintheory
Tell me more about the 68 BG's.  Will they have that piercing sound like in sympathy for the devil.  A lot of people don't like that piercing sound, but I love it.  I noticed that the boutique tele bridge pick ups that I have played like the lollars sounded too mellow and refined, but I have yet to try the bk tele pickups.  Only the fender tele pickups had the tele sound I had in my head, particularly the custom shop nocaster.  However, I still feel like I can do better than fender pick ups.  Also what do you mean by icepicky?  Do you mean that the treble notes were too shrill or piercing?  Would you consider the tone in Sympathy For The Devil's guitar solo icepicky?  If that is icepicky than I want it.  For some reason my ears like really bright tones.
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Nolly
The '68s are very trebly pickups, in keeping with the early CBS-era instruments. The bridge is weaker than the Country Boy, but has an AV magnet so does feel like it can push a little harder.
Honestly though, the majority of pickups are designed to not be as bright as you're going for. If you get yourself a Brown Sugar set, you'll have the mid grind you want, and if you want more treble you can simply dial in more on the amp. Also, have you considered getting a treble booster pedal?
braintheory
Will any of the bk tele pu's at least be as bright and sharp as the fender tele pu's.  If they can be as trebly as the stock pu's in teles like the nocaster, 52 reissue, american standard tele, and mexican standard tele then that is good enough for me.  I am definitely looking for a classic tele sound, but if none of the bk tele pu's are as bright and metallic as the fender tele pu's then IMO they are not authentic sounding tele pickups and are not capturing the true essence of a telecaster and rather they are going for their own sound, which is not a bad thing, but not what I'm looking for.  I think that metallic sound in the bridge is as important to capturing the true tele sound as is that piercing treble.  One of you said the BG's won't be as icepicky as the real tele pu's.  I'm still not 100% sure what icepicky means, but if means what I think it does then I think the bk tele pu's should have because otherwise they really missed the mark in making vintage tele pu's, unless of course I have the wrong definition of icepicky.  I don't mean to sound like I'm saying negative things about bk tele pu's because I have no idea since I have never played and even if they don't have that signature tele sound they still may be amazing pickups in their own way, so don't get the wrong idea.  Thanks for the help.  Also I don't think I need a treble because all the fender tele pickups I played had enough, only the non-fender boutique pickups I played lacked the treble, but they still were better quality pick ups and to me sounded much better, but just did not sound like a traditional tele to me.
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
braintheory
Sorry I made a few silly typos let me rewrite the ones with typos:
-but if it means what I think it means then I think the bk tele pu's should have it.
-because I have no idea since I never played them
-Also I don't think I need a treble booster because all the fender tele pu's that I played had enough treble
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Nolly
I think you are getting confused about the Blackguard series. It's a collection of 4 very separate pickup sets, that are each extremely authentic recreations of notable Tele pickups.
The Flat '50 Blackguard set that people have referred to as not icepicky are replicas of the pickups found in the original Broadcaster guitars, which were wound rather hot at around 10.5kΩ. It's not the bright and "metallic" sound you're referring to at all, but it is an accurate reproduction of the pickups from that brief period.
The '68 Stagger Blackguard set that I mentioned earlier is very bright, so if that's what you're after it's a good choice.
The '55 Stagger Blackguard set is pretty much the definitive Tele tone, as I described earlier.
I think this thread has given more than enough information for you to be able to make a decision  :)
the BG50 and 55 provides true tele tone from the fifties and are easy to tailor on your amp to your flavour. I think the '68 is something special, since is - as Nolly says - way brighter. I could be a good choice, but I think the other two have more punch and grind. If you like nocaster-tones, they are the way to go.
Keep in mind that the secret to make different tones on a tele is in the toneknob of the guitar. I often play my Tele with the toneknob just on half, by example for fat rythmchops. When you go for the '68, just experiment with the toneknob to find the sweet spots.
braintheory
So could the BG 50 and 55's sound as bright and sharp as the fender nocaster pickups with the tone knob all the way up?  Also you think the 50 and 55's will be better choices than the 68 because of the extra grind and punch?
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Yes, I think the '50 and '55 are more versatile and deliver telespank, depending on the amp you use. Anf when I mean spank: bright but no razorblade.
braintheory
How do the BG 52's compare to the 50's and 55's?
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
