Line 6 Pod HD 500
Started by mkh02, December 22, 2010, 06:48:19 PM
Madsakre
Quote from: BigK on December 26, 2010, 05:37:58 PM
I got one of these as a present when I had to move in with a mate as I got a new job in stoke and couldn't take my Powerball and 4x12 with me.
You can get some OK tones out of it with fiddling. Through headphones or good computer speakers/monitors its better than a pod xt and you can get some reasonable tones out of it but it still doesn't have the 'feel' anyway near that of a valve amp.
I find to get a good high gain tone you quite often have to cut quite a bit of bass using the EQ to stop it getting muddy, also the JCM800 sounds like an angry legion of wasps which is very dissapointing.
It does sound way better through a valve power amp and proper speakers but then that kind of defeating the object for me as I use it for 'quiet' practice and if I'm going to be using a valve amp I would use the Powerball.
Yes the presets are shocking and it does sounds better with the volume rolled off a bit on my Tremonti's as it doesn't seem to like hot pickups.
The dual amp mode is cool, I like to mix an Uberschall and Dual Rec together and it does sound pretty good. and using the dual amp with the same amp with different cabinets and/or mics is a good way to fill out the sound a bit.
Basically without getting an axe fx there isn't much better out there. But for the price I probably wouldn't buy it if I was paying for it.
You got one as a present?? :S What does your friends wipe their buttocks with? Sterling Pounds?
Cattlepress
BigK
It was from my Nan as a well done for getting the job/early XMAS present. She's not even that well off, just VERY generous.
PRS Tremonti - PRS Silverburst 594 - Ibanez RG550EX, RG570 & RG721FM - LTD SC 500 -  Schecter 006's - EVH 5150III 50w into custom Zilla Vert 2x12
