Author Topic: Bare Knuckle Ceramic Warpig -does it suit my need? And bridge pickup recs  (Read 8184 times)
DvE
How would you compare the aftermath to your emgs?  Could you also answer my question in regards to what would happen if I installed the the pickups in the bridge postion (it's a few posts up)
I cannot compare the emgs and the aftermath directly, since they were in different guitars and its some time ago. But I really like the aftermath for what I am doing (with this guitar mostly metalcore). The aftermath is less compressed, responses better to pick sensitivity, and lets you still hear the tone of your guitar. I still have my emgs lying around. For me, the aftermath is a best-of-mix between the painkiller and emgs, if that makes sense...
Sorry, I dont get your second question  :? Maybe it's my bad english.
adam124
So this is what I need in the bridge position then?
http://www.bareknucklepickups.co.uk/shop/index.php?main_page=product_info&cPath=1_94&products_id=358
Also, what's the difference between 4 and 2 conductors and long and short legs?
I also need a real nice clean pickup to complement the aftermath. What do you guys suggest? I want something that will be able to help me achieve something similar to this.
http://www.youtube.com/watch?v=BEg_sxcBhw0&feature=relmfu
(skip to 1.23)
Madsakre
short story. 4 conductor for coil split etc. the 121 comes with a 5 way selector.
Get short legs for versatility, if you wanna swap it into a trem guitar later on.
as for neck pickup.. i dont know? I dont use neck pickups
Cattlepress
Jack
If you want to sound like periphery then depending on your setup I'd get a Cold Sweat bridge and a Painkiller neck, as that's what they used on the record.
