Author Topic: I just bought a Gibson abomination  (Read 38474 times)
Re: I just bought a Gibson abomination
« Reply #30 on: April 04, 2011, 02:22:53 PM »
I had one of those some time ago, just in black. It was a wonderful little axe, definitely. The neck was perfect and the resonance was staggering!
yes, the resonance is quite surprising
Loomer
« Reply #31 on: April 04, 2011, 02:37:19 PM »
It was a matter of impulse shopping for me. I saw it in a shop that was having a clearance sale some years ago, and my mate who I was with said I should try it out, mainly because it looked like arse  :lol:
But then, having sat down and played it unplugged I just went "$%&#in' hell. I need this". Sure enough, 10 minutes later my VISA started bleeding :D
I kinda miss that guitar now though :(
« Reply #32 on: April 04, 2011, 03:06:11 PM »
the finish looks shitee though - looks like someones attacked a thin white finish with some coarse sand paper (which they probably have). worst aging job i've seen in my live. but it might just be right for a punk rock looking V..
I know what you mean - I was going to buy one of those budget Juniors they're making at the moment, but when I saw one in the flesh the finish put me right off.  It looked exactly like they'd slapped on one coat of Dulux white primer then given it a quick sanding.  Horrible.
Nothing against "rustic" finishes in general though - I like the Edwards "Lacquer Taste" guitars which have loads of sinkage into the wood grain.  But they still feel like finished guitars rather than cheap DIY projects.
Loomer
« Reply #33 on: April 04, 2011, 03:12:04 PM »
It's funny how people are different  :lol:
I actually quite like those finishes!
« Reply #34 on: April 04, 2011, 03:43:51 PM »
I think you should put 3 filtertrons in it. I don't know why.
sorry.
Loomer
« Reply #35 on: April 04, 2011, 03:45:14 PM »
sorry.
Some people say "Why?!" and others say "Why not?"
The latter category tend to have more fun :lol:
« Reply #36 on: April 04, 2011, 07:16:30 PM »
don't like the stock pickups /at all/ very mushy. the neck is ok though.
« Reply #37 on: April 04, 2011, 09:34:59 PM »
What are they, 490T and 490R?  They're Alnico II, not ideal for bridge pickups (IMO), but as you say the neck is not bad.
« Reply #38 on: April 04, 2011, 10:53:46 PM »
yeah exactly.. in fact the neck+bridge combination is probably the best sound on reflection.
the internetz tell me a good modification is to stick A5 magnets in these pickups. i can sort of see why.
anyroad, looking forward to ripping the electronics out!
« Reply #39 on: April 09, 2011, 09:00:03 PM »
The story so far.
The Dirty Fingers in bridge burns (burns like fire). The one in the neck sounds a bit dark, but its not my parallel wired one. I think I'll try a mini-humbucker in the neck position soon.
So the volume pot is put in the strat position, I spent a while measuring it out, and then realised if I'd have moved it over just a little to the right, it would have lined up with the other controls. Oh well.
The volume control didn't need too much adjustment to the control cavity actually. I drilled most of the extra space needed, and then knocked it out with a screwdriver-chisel.
Also added pickup rings, a black truss rod cover and a nice capacitor.
Any thoughts?
« Reply #40 on: April 12, 2011, 01:34:10 AM »
Humm a little better, but I like it without p.u. rings and with the white TRC
« Reply #41 on: April 12, 2011, 01:41:22 AM »
Not loving it, to be honest.  I don't like the volume control placement (although obviously that's your personal choice) and I think the black pickups and rings (and truss rod cover) look weird against that vast expanse of white (why did they go for a black headstock?  :? ).
Covered pickups (minibuckers?) would look better.
Sorry!
« Reply #42 on: April 12, 2011, 09:59:20 AM »
I know what you mean about the black truss rod cover (i assume its from a Goth or Voodoo model), I was already considering changing it back.
With the rings, I'm not decided either way. I'm pretty much definitely going to try a mini-HB in the neck. Do you think a black or chrome cover would look best there?
Kent Armstrong do some black firebird mini-HBs. The mini-HB in the neck will definately need a ring (I think they look sh1t direct pickguard mounted), so the dirty fingers in the bridge might look odd without one.
I think I've done the best I can with the controls considering I wanted the volume where it is for violining. I kind of don't mind them like that, is a hell of a lot nicer than it was before :) (IMO)
« Last Edit: April 12, 2011, 10:02:38 AM by gwEm »
« Reply #43 on: April 12, 2011, 10:09:50 AM »
Chrome cover for the mini, deffo!
« Reply #44 on: April 12, 2011, 10:26:05 AM »
I hear you, and will take this in to account with all the many other factors when making my decision :) The idea is for a stripped down metal look, so I've stayed away from the idea of chrome parts, though I must admit, all the black is a bit too much on this guitar for some reason - although it looks fine on my white Greco. Which is weird.
