Wiring with 3-toggle
Started by Laimon, April 17, 2011, 01:14:39 PM
Quote from: Laimon on April 17, 2011, 11:20:08 PM
That is actually what I had in mind, brilliant!
Except that, now that I know of it, I think I prefer the 6-way toggle...more possibilities, no? :)
True, but sometimes simple is better.  :wink:
Laimon
Quote from: Philly Q on April 17, 2011, 11:39:04 PM
True. That's why I didn't want a 3-way selector + a push-pull pot ;-)
ShredHeadJHJ
Quote from: Laimon on April 17, 2011, 01:26:55 PM
It's an Agile Interceptor Pro (http://www.rondomusic.com/product3682.html)
JEEZ man, that guitar looks awesome and it's only $800 new. Man I need to get a 7 String Agile!!! LOLOL! GASGASGASGASGASGAS
Laimon
Quote from: ShredHeadJHJ on April 20, 2011, 12:50:41 AM
Eh eh man, it's a really nice axe ;-)
But I can not stand the pickups, and that is a minor problem if you want to change from EMG 707 to Duncan Blackouts or viceversa (they have same electronics and same size). If like me instead you want passive pickups (and if you're here I guess you do) you will need to change all alectronics (almost) and do some magic with the wood to fit the passive pickups (whose baseplates are larger than the cavities in the body). I will do it in the next months and maybe post about it, if you're interested.
Other thing, the neck is a bit thick, but I can't complain really as it's really comfortable, even being thick :)
If you need more advise, pm'me ;-)
You need to order a set with one magnet reversed for this to work properly and hum cancelling
I do it all the time
You will need the 12 pole switch - 4p3t
One side will act like a 3 way toggle and the other side will deal with the coil splits
I have a diagram somewhere here for it
You also need to turn the wiring "inside out" on one pickup - red and black become the coil tap point and green and white will be the hot and earth
Laimon
Quote from: FELINEGUITARS on April 20, 2011, 01:29:35 AM
Aehm...I'm not sure I get anything  :oops:
It's maybe better if I tell you what I am gonna do (and you can tell me if there's anything wrong), which is the following:
a) buy a set of calibrated open Cold Sweats (and all necessary pots, jack sockets and so on)
b) buy the free-way selector suggested in one post above
c) follow the diagram for the pickups in all points, except connection to the selector
d) use the diagram for the selector to complete the work, obviously properly mapping the cable colors.
Do you find any flaws in this plan? I never heard of the reverse magnet, maybe that's what they for calibrated sets indeed?
Quote from: Laimon on April 20, 2011, 08:42:12 AM
Hi,
Calibrating and magnet reversal is not the same. Calibrating only means that you get bridge and neck pickups that are balanced to each other. The magnet orientation has nothing to do with it, and reversing the magnet in one pickup does not make the pickups "uncalibrated".
The normal magnet stagger going from bridge to the fretboard is Southpole - Northpole - Northpole - Southpole.
If you use the coil split to activate the inner coils you will have both Northpoles on and cannot achieve a humbucking effect.
If you reverse the magnet in one pickup you get South - North - South - North (Neck PU reversed) or North - South - North - South (Bridge PU reversed). Activate both inner coils (or both outer coils) and you will get the humbucking effect.
Just specify with your order that the pickups are going into a guitar with PRS rotary wiring, then they will come with a proper magnet stagger. The 4 conductor wire will facilitate all wiring options.
Laimon
#22
Quote from: darkbluemurder on April 20, 2011, 08:55:25 AM
Hi,
Thanks man, you seem to know a lot about it ;-)
I knew a few of the things you mentions, among which the usual south - north - north - south disposition of the coils, and I see your point in getting the humbucker sound.
The problem is that I don't think I *want* the humbucker sound, there. My intention was really to obtain this double coil, crisp sound for the cleans by selecting the innermost coils of each pickup.
First example that comes to my mind, listen to Erotomania by Dream Theater, right after minute 2:50. I believe those cleans are made with the two inner coils...and they don't really sound like an humbucker.
But again, I might be wrong. I'm really not experienced (yet) with technical details, so please feel free to contradict me ;-)
You NEED
A pickup set with the magnet reversed in one pickup - like a PRS guitar with a roatary selector would use
You need the 12 pole 4P3T type switch (Dimarzio sell them, but they can be got from Allparts too)
This is the wiring that John Pettrucci used and also features on certain Musicman Axis guitars too
The Freeway switch will not help you as far as I know - although someone may have figured out some clever coil splitting option with it
And Philly Q gave you links to a Dimarzio colour coded version of the diagram too
Here it is again - just convert the Dimarzio to BKP colours with the pickup s with the reversed magnet and all will work well.
Quote from: Philly Q on April 17, 2011, 07:52:59 PM
This is like the John Petrucci Ernie Ball/Music Man wiring.
You need a special 4-pole, 3-way switch:
http://www.allparts.uk.com/online-shop/guitar-bass-parts/electronics/switches/on-on-on-4-pole-toggle-switch-12-terminals-p-4064.html
Here's the wiring diagram:
http://www.dimarzio.com//media/diagrams/D.pdf
Laimon
Quote from: FELINEGUITARS on April 20, 2011, 09:27:25 AM
You NEED
Ok, I believe now that I might have to ask for the reverse magnet, but I don't think I can't go for the free-way selector, which does allow coil splitting, check this: http://www.stewmac.com/freeinfo/i-0040/i-0040.pdf
I was also thinking: wouldn't mounting the neck pickup upside-down (and then appropriately reverting the wires) be the same as having the reverted magnets?
OK - I've looked at the stew-mac diagram and yes it does seem to offer those options
The reverse magnet choice just allows the two single coils on together to be hum cancelling too
You can achieve much the same odds by turning the pickup around but it will mean a complete brainstorm over  which wire to go where (and you end up with a non symmetrical arrangement of screw poles which some people won't like visually )
If you have to order the pickups anyway - what is the problem asking for a magnet flip when you do
If in doubt go through a dealer/stockist /installer who understands what you are trying to achieve (like us for example ) and they will make sure the order is placed correctly for  the application you seek
I actually have some free-way switches in stock so I might have a look at one too myself.
Laimon
Quote from: FELINEGUITARS on April 20, 2011, 10:41:34 AM
Sure, I will ask for the magnet flip, I was just curious to know whether my intuition was correct ;-)
Laimon
Hi guys,
I resume this thread as in a few days I'll finally have the chance to realize my plan for which I bugged (some of) you some time ago.
Quick recap: I own an Agile Interceptor Pro with Seymour Duncan Blackouts, and I wanted to change to Bareknuckle Colde Sweats. Furthermore, I wanted to have the coil splitting without using a push-pull pot.
So here is what I've done so far:
a) bought the Cold Sweats, calibrated, with reversed magnet in one of them
b) bought all the right pots (550K) and capacitor
c) bought a freeway toggle (http://www.stewmac.com/shop/Electronics,_pickups/Components:_Switches_and_knobs/Free-Way_Pickup_Switch.html)
And here is what I suppose I should do to make it work. First, remove the Blackouts and all electronics. Then, take the wiring scheme for the freeway (http://www.stewmac.com/freeinfo/i-0040/i-0040.pdf) and properly map the Bareknuckle conductor colors to the colors in the scheme. Once I figure the mapping, I apply it for one humbuckers, and I reverse it for the other (due to the flipped magnet).
Can anybody confirm this is right?
Furthermore, I'm a bit confused as to the naming of conductors, most talk about north-south start-finish, but others use different names. In the case of the Bareknuckle pickups, they talk of screw and slug coil...which is supposed to be north and which south?
Thank you guys in advance for any help.
PS: I might take a few pictures to show you the work ;-)
Generally, "North" is the slug coil, "South" is the screw coil.
For BKP (hopefully someone will correct me if this is wrong):
North start = Red
North finish = Green
South finish = White
South start = Black
The Stewmac diagrams seem to be using Seymour Duncan's colour coding.
I'm not sure if you need to reverse the wiring due to the flipped magnet or not - looking at those diagrams is giving me a headache! - hopefully Feline will chip in.
Laimon
This is what Feline said before... I am indeed not sure this step is needed: if the magnets are already flipped, so should the wires' "function", no?
