Author Topic: What to do about my marshall?  (Read 7044 times)
Re: What to do about my marshall?
« Reply #15 on: April 23, 2011, 04:10:32 PM »
I'd try a PPIMV first
clyde billt
« Reply #16 on: April 23, 2011, 10:40:35 PM »
After spending the afternoon thrashing the living daylights out of it, checking out YouTubes and pricing attenuators I think I'll try the PPIMV.
Dmoney in what way does it screw with the presence?
Also, if it doesn't give power valve saturation at lower volumes does it still have all that gain when whacked up to 10?
Sorry sgmypod, computer says no
  • Truly bad since 1972
« Reply #17 on: April 23, 2011, 11:40:50 PM »
Lmao
« Reply #18 on: April 24, 2011, 12:31:19 AM »
Basically, the presence works by taking the output of the amp (tapping it from one of the output transformer secondaries) and feeding it back into the phase inverter 180 degrees out of phase. so when you turn the presence, you mix more or less out of phase high frequencies with your output. more out of phase signal cancels out the high frequencies more and vice versa.
less output = less negative feedback... which is why presence and depth controls can be less responsive at low master volume settings.
The relationship between the phase inverter output, power valve input & output, and feedback is usually fixed. If you add a post phase inverter master volume to lower the volume of the amp, you alter that relationship.
It means you can be driving the PI quite hard by increasing the preamp gain/volume, but the output of the power section can be small (quieter amp), which means you get less negative feedback into the PI, which in turn effects the presence control. Any master volume will effect the feedback for those controls, but a normal Pre-PIMV that you'd find in a JCM800 for example, doesn't sit between the PI and the power valves and doesn't effect the power section the same way.
It's a while since I've used a PPIMV (not the Lar/Mar suggested) but basically, if you turn it right the way down and the preamp all the way up (which is dumb), you can get this sound which is the PI is distorting with no power valve breakup and very little feedback to tame the high frequencies as your presence won't really do anything. As I recall the result can be a bit harsh... BUT... using a PPIMV that way is a bit silly.
Different PPIMV's sound and react differently. The Lar/Mar is detailed in Ken Fishers trainwreck pages. I think It's meant to be the one to go for to really retain the sound of the amp, and I think a lot of Trainwreck enthusiasts opt for this PPIMV in Trainwreck Express clones, since those amps don't have master volumes either. when on '10' the amp should be the same as it is 'stock'.
I've never used the Lar/Mar though, I've used other methods (methods 3 & 1 in the trainwreck pages). Others here may have actual experience of the Lar/Mar. I don't think it will give you power valve breakup and lower volumes like an attenuator would.
what videos did you see?
since this requires modding the amp you should be sure its the way you want to go.
http://home.comcast.net/~jbjdav26/1992/1992%20Dual%20B+%20PPIMV.JPG
http://blueguitar.org/new/schem/trainwreck/the_trainwreck_pages.pdf (page 14 & 24 of the pdf)
clyde billt
« Reply #19 on: April 24, 2011, 10:10:32 PM »
Mr Dmoney.
Thanks for that technical explanation.
I was looking at PPIMV mods on YouTube and came across these
http://www.youtube.com/watch?v=8AACt1W7IFs
http://www.youtube.com/watch?v=oDXvKAEqCqo&feature=related
http://www.youtube.com/watch?v=UfgVXE18vHA
http://www.youtube.com/watch?v=40XBZEKqI84
I know that you really can't make a properly informed judgement just based on a compressed vid but I need to do something.
As I said I'm constantly changing my mind.
I'll be doing a phone round for the prices of getting one installed, as well as keepng an eye out for attenuators.
I'll be away from home for a month at the end of next week so I'll have a bit of time to decide.
Or come up with more choices to confuse me (part ex on a 5E3 for example)
« Reply #20 on: April 24, 2011, 10:21:50 PM »
oopfh! that last clip sound like a beast! it has a depth mod and some other stuff done to it though.
If you like those a lot then I'd go with the Lar/Mar. I don't think its a hard mod. The biggest decision will be if you want to drill the chassis for the extra control, but like I think Hunter said, you can remove one of the speaker outputs and install it there. That seems to be the suggested method.
http://metroamp.com/wiki/index.php/Lar/Mar_PPI-MV
EDIT: after reading that page on metroamp I have to say I was wrong about who developed the Lar/Mar in that other post.
« Last Edit: April 24, 2011, 10:25:22 PM by Dmoney »
keith
« Reply #21 on: April 25, 2011, 04:20:54 PM »
Think I agree with DM about the fourth one but check this out as well its class
http://www.youtube.com/watch?v=j2Mm0NXr0_A&feature=related :D :D :D :D
made me smile anyway......sorry Clyde couldnt resist
« Last Edit: April 25, 2011, 04:23:51 PM by keith »
Orange Dual Terror Head
Zilla 2x12 cab
