Author Topic: Rebel Yell, Holy Diver and Seymour Duncan JB  (Read 16057 times)
  • Random Solution
Re: Rebel Yell, Holy Diver and Seymour Duncan JB
« Reply #15 on: May 02, 2011, 09:41:11 AM »
If the Holydiver is a thicker less bright sounding version of the JB I will be in tone heaven
It is  :D Review to be posted shortly.
« Reply #16 on: May 02, 2011, 10:13:20 AM »
these are from james lugo's 2009 pickup shootout
I think these show the differences very well. Thanks for posting, Eric.
JagAlskarKatter
« Reply #17 on: May 21, 2013, 10:47:07 PM »
I had a JB in my Ibanez and I swapped it out for a Holy Diver set because the JB was too thin sounding and lacked sustain and clarity under gain. By comparison, the HD has a much thicker, saturated bottom end which is really nice for huge rhythm sounds \m/  And as for the neck pickup, the tone is really open with lots of fluidity and an earthy, vocal-like lead tone. The perfect pickups if you like the mids of a JB but want a more ballsy sound :)
darrenw5094
« Reply #18 on: May 24, 2013, 04:55:54 PM »
Just pulled the JB from my Charvel for a Holy Diver.
Diver far less hot, Diver less bass, Diver clearer tone.
Having not liked the JB in the Les Paul Standard i have, i think it was ok in the Charvel at crunch amp settings, the hot output was great for leads.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
« Reply #19 on: May 25, 2013, 04:27:21 AM »
it feels a little less bassy cause it needs to be set a lot closer to strings than the JB, due to its lower output
darrenw5094
« Reply #20 on: May 26, 2013, 04:48:45 PM »
The newer Charvels don't have any way to adjust height, they are direct mounted and have nothing underneath to push the pickup up. I am about 4mm from the strings.
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
fdesalvo
    • Frank DeSalvo's Music on Soundcloud
« Reply #21 on: May 28, 2013, 06:21:27 AM »
U can shim the pickup with foam or a bit of wood.
darrenw5094
« Reply #22 on: May 28, 2013, 03:36:17 PM »
Sticky foam......that's were it's at. 8)
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
