Author Topic: What's the world coming to? Twinfan's getting racked :0O  (Read 5760 times)
Frank
Re: What's the world coming to? Twinfan's getting racked :0O
« Reply #15 on: May 04, 2011, 11:22:30 PM »
I for one welcome our new robotic MIDI overlords
« Reply #16 on: May 04, 2011, 11:49:59 PM »
Mr38th/PhillyQ - it took me about half an hour to set the whole thing up, including presets, so ANYONE can do it!  :lol:
The problem for me would be not only figuring out how to set it up..... but working out what I actually wanted it to do!  :lol:
JDC
« Reply #17 on: May 05, 2011, 02:41:06 AM »
says the guy who works in IT ;) (if memory serves correct)
forgot about that EQ pedal, how you been using it?
« Reply #18 on: May 05, 2011, 05:47:25 AM »
Nice one. The RJM stuff is great, much better than the Voodoolab GCX.
I find the mastermind a bit limited in its possibilities, but it's got a nice small foot print, which was probably one of the main reasons for you to chose it.
Are you gonna make an interace in the rack or plug in stuff from the board directly into the rack units? What cable will you use to rack it all up?
  • Truly bad since 1972
« Reply #19 on: May 05, 2011, 07:26:23 AM »
Midi - Dave!! What is the world coming to
« Reply #20 on: May 05, 2011, 08:19:58 AM »
The Mastermind does all I need it to do Hunter, trigger the stuff in the box near the amp, and the amp!  I'm not sure why you think it's limited in use, unless you mean it only has 5 direct access buttons?  That's fine for me, plus the function button triggers an 'alternative' setting, so you have fast access to another seting above those 5 e.g. dry rhythm to wet rhythm with one switch  :)
I've got a bunch of mid-quality short patch leads hooking up the four pedals connected directly to the RG-16, and the pedals will be velcro'd to the top of the unit.  I'm not spending a fortune on gold plated platinum cored cables made from space dust  :lol:
I have the RJM 7-pin MIDI cable between the two units which powers the Mastermind from the RG-16.
tomjackson
« Reply #21 on: May 05, 2011, 09:19:33 AM »
Here you go TF, this is the rack I was onabout....
« Reply #22 on: May 05, 2011, 09:38:00 AM »
Cheers Tom - I'll take it  :)  PM sent.
Bob Gnarly
    • My tunes
« Reply #23 on: May 05, 2011, 11:06:59 AM »
Love a bit of MIDI. In my old band we played along with MIDI sequences, and all my programme changes for my Digitech GSP2101 were sent at the same time. So my sounds would change with no pedal dancing.
The down side was that some people thought I wasn't playing.
HairyChris
« Reply #24 on: May 05, 2011, 11:46:15 AM »
Have you thought about getting a rack drawer and velcro-ing pedals to that? I think that you may need 2u for that solution as I don't think that 1u give enough space...
« Reply #25 on: May 05, 2011, 12:14:22 PM »
Sorry I didn't wanna come across as the righteous guy  :)
Indeed I refer to the number of buttons on the unit and the display. I find that when you go from direct access to presets, the latter can become a bit limiting when you have a few fx and channels and boosts. On the GSC-3 I switch both, presets with full settings and the channels extra, because there are 10 buttons. Also has audio loops and a buffer in case there is still stuff on the board. But it's not as high quality as the RJM I suppose.
For cables, I went away from sky dust  :lol:
All Mogami 2524 for me now. Cheap and sounds great. I became good in soldering meanwhile, so did em myself on custom length.
Plus I used one of these and locking neutrik jacks as well as XLR5 pin for Midi to get all my rack connections tidy and quick in one place. But that might be overkill.
Anyways, enjoy the new controllability, it's great once all is set.
« Reply #26 on: May 05, 2011, 12:47:44 PM »
I only need a few core tones, so I can easily access all I need for my covers band.  Very, very tasty  :)
