Author Topic: Gibson Les Paul Standard: DiMarzio 36th Anniversary or BareKnuckle Mules?  (Read 12781 times)
Hope they will sound great in your les paul.
YouŽre welcome mate.
One more thing:
In order to get the most of them, when fitting them in keep in mind that BKPs more sensitiv than most other PUs to height adjustments. YouŽll need to do some work with those screws to get the tone you want.
metale
Sorry on the offtopic, but I have a quick question on the Mules. If one was to order an open mule calibrated set, having the neck humbucker with zebra and bridge with reverse zebra, how can it be set on the online shop page? Would them have to be ordered as separate singles?
Thanks
Easiest thing to do is call BKP direct and order that way, or order through a dealer like Feline Guitars (as I did ina similar situation).
There used to be a comments box for this sort of stuff when ordering online, but I don't think it's there any more?
Boydie
Metale
I would strongly suggest that you give BKP a call to discuss
It is difficult to get across that you are not dealing with any old company
If you give them a call and explain what you are considering I am sure they will make you a set AND calibrate them for you to ensure that all is well
