Author Topic: Hot and soft Buckers  (Read 6335 times)
ztikmaen
Re: Hot and soft Buckers
« Reply #15 on: May 20, 2011, 12:11:52 AM »
Oh and is it possible to order normal P90s and request them to be in humbucker size? Because I saw somebody bought a humbucker sized Pig '90
I have one of these :) Even with a ceramic magnet :)
Its amazing.
Wow, sounds intense... You should put it in a GoldTop to give people a shock :D
In terms of P90s, I think I'm leaning towards the Nantucket... I was looking at the Supermassive and Stockholm but the Stockholm's clean demo is kinda below par :/ Can't really concentrate because the guitar is out of tune
If I go for the P90s, I want a vintage, compressed, and middy sound in the bridge.
Guitars:
Warmoth Jazzmaster
Telecaster Standard
Ibanez RG370
Ibanez GSZ
Amp: Fender Hot Rod
Zaned
« Reply #16 on: May 20, 2011, 12:06:58 PM »
Well I'd probably leave that booster on :D
Thanks for the feedback Zaned
So it would be better to boost a soft pickup than tone down a high output pickup?
And what were you saying about pick attack? So if I want more pick attack I'd be better off with a higher output pickup?
What's the biggest differences between high and low output pickups?
I can't really put that pick attack into words :) It's a matter of compression too, which high output pickups tend have more of. And it's very dependent on the guitar too, what kind of a tone it has and what you want to highlight/suppress with the pickups.
When choosing pickups, I tend to go for a pretty balanced sound; warm but clear, and with bite when I want it. And still keeping in mind what I feel that particular guitar excels at. After I've accomplished that, I've noticed that I can play pretty much anything with it :) Not that I would choose my cold sweat equipped PRS McCarty to play Hank Marvin; I'd choose my alder bodied strat with slab board '59s for that. It can still rock hard after Hank has left the house.
About boosting, different amps just react differently to that. Try getting a highish gain hard rock tone from a vintage plexi and low output pickups. But use a booster, and you have something that's been used for more recorded hard rock tones than can be counted. Modern amps tend to have enough gain by themselves, but a booster can still bring you different flavours..if the amp likes boosters. Some don't.
I do like the woody, dynamic and honest tone of low output pickups, that's the direction I've leaning to lately. Which probably means I'm getting more guitars and BKPs in the not so distant future 8)
Hmph. Hopefully some of that makes sense.
-Zaned
Paths are for followers.
ztikmaen
« Reply #17 on: May 20, 2011, 12:33:07 PM »
Yeah, totally makes sense
So I guess for me, choosing a neck humbucker is hard. I don't know if I should choose a big wide open clean pickup, or a more compressed and pick-attack-y powerful one that doesn't mud up. I guess (from what I hear) that a Mule is the perfect mid point. But I was wondering if I should go EVEN softer and go with a Stormy Monday or PG Blues (although the PG sounds like a bit of a funny one)... After all, my neck pickups are almost exclusively for my cleans
« Last Edit: May 20, 2011, 12:36:06 PM by ztikmaen »
Guitars:
Warmoth Jazzmaster
Telecaster Standard
Ibanez RG370
Ibanez GSZ
Amp: Fender Hot Rod
BigB
  • Let's rock !
« Reply #18 on: May 20, 2011, 10:11:35 PM »
So do you guys have Humbucking guitars, one for cleaner stuff, and one for drive?
My Vox Custom 24 has Crawlers neck and bridge, and my SG now has a Mule neck and NB bridge. Both work fine from pristine cleans (with special mention for the SG / Mule neck which is just incredible when it comes to clean tones) to over the top gain levels.
Now if I could afford it, I'd get me some ES335-like semi-hollowbody with Stormy Mondays just for clean / slight bluesy overdrive tones.
ztikmaen
« Reply #19 on: May 21, 2011, 04:52:39 AM »
So instead of one for drive and one for clean, you kinda went more for the "different flavor" approach?
Sounds good... I'm imagining what it would be like to have three guitars that had really nice cleans AND drive sounds in the variation of singles, P90s, and Humbuckers :O
Whole spectrum right there apart from semi hollows
Guitars:
Warmoth Jazzmaster
Telecaster Standard
Ibanez RG370
Ibanez GSZ
Amp: Fender Hot Rod
BigB
  • Let's rock !
« Reply #20 on: May 22, 2011, 05:06:42 PM »
Well, it wasn't really a "rationale decision" kind of process. The Vox has been my one and only guitar for about 20 years and it's so much part of me that I couldn't let it go, despite the (newly acquired) SG being by now my #1. Now having two "compatible" (even if somewhat different) guitars is a good thing - at least you have a decent backup for gigs.
FWIW, I also have a Telly for the fenderish singlecoil tones, and thanks to BKP it also happens to sounds as good from clean to heavy gain, but it doesn't get that much use. And yes, some P90s axe would be a nice addition to my rig, but I just can't afford another decent guitar ATM and I'm rather a "one-guitar-to-rule-them-all" kind of guy anyway ;)
ztikmaen
« Reply #21 on: May 22, 2011, 08:46:38 PM »
Thanks BigB, hopefully I can make those awesome irrational like you :D
Oh btw, how much hotter is a Black Dog compared to a Mule? I want one of those, possibly a Stormy Monday, in the neck with an Abraxas bridge. But I'm guessing the Stormy Monday may be too mellow
Guitars:
Warmoth Jazzmaster
Telecaster Standard
Ibanez RG370
Ibanez GSZ
Amp: Fender Hot Rod
