Author Topic: gainist pedals  (Read 11864 times)
Cattivo Ragazzo
gainist pedals
« on: January 12, 2006, 10:02:54 PM »
What is the most gainist pedal out there? I've had a lot, but none have given me enough gain. Stuff like the ds1 is no where near enough, and some of those higher gain boss pedals have a tone that i don't like. I would try the digi death metal, but i've not heard a good word about that one. I have a tube amp, but the dist at the highest level is just not enough, I don't like the horridness of using a distortion pedal + the amps own distortion, and I like the amps own distortion, so it would be cool if there  is something that I can use to just boost the gain? If not, recommend me a pedal if you can.
gainist pedals
« Reply #1 on: January 12, 2006, 10:06:46 PM »
I'm not really big on pedals, I like amp distortion, but I had a line 6 uber metal that had more gain than I can imagine anyone ever actually finding a use for.
Cattivo Ragazzo
gainist pedals
« Reply #2 on: January 12, 2006, 10:25:26 PM »
I dislike all the line6 stuff ive tried.
adamr
gainist pedals
« Reply #3 on: January 12, 2006, 10:25:59 PM »
sounds like you want an overdrive pedal rather than a distortion. theres loads out there. For starters theres the Boss SD-1 and MXR wylde overdrive. Tim uses both i think so theres a good place to start.
Cattivo Ragazzo
gainist pedals
« Reply #4 on: January 12, 2006, 10:27:30 PM »
Doesn't that just make my amps distortion muddy? I have to use the pedal through cleans?
adamr
gainist pedals
« Reply #5 on: January 12, 2006, 10:29:33 PM »
Quote from: Cattivo Ragazzo
Well not if you buy a good one and have a decent amp it shouldnt. But an overedrive wont give anywhere near the distortion your looking for if you use it over a clean tone.
Cattivo Ragazzo
gainist pedals
« Reply #6 on: January 12, 2006, 10:30:43 PM »
I see, what about a tube screamer, is this an overdrive pedal, like a 808?
adamr
gainist pedals
« Reply #7 on: January 12, 2006, 10:32:38 PM »
Im sure it is an overdrive yeah, personally i have no experience with tube screamers but im sure others on the forum have. I've heard good things about the mods keeley do for them.
Steve-Mr Pig 2U
gainist pedals
« Reply #8 on: January 12, 2006, 10:37:39 PM »
The Highest gain pedal Ive used is the AMT Rammstein pedal, its insane amounts of distortion. I prefer a good overdrive though.
adamr
gainist pedals
« Reply #9 on: January 12, 2006, 10:39:16 PM »
Quote from: Steve-Mr Pig 2U
 whats that one like? time for a google search me thinks...
willo
gainist pedals
« Reply #10 on: January 12, 2006, 10:51:23 PM »
how about just a simple boost pedal, going into the pre-amp? It should give you significantly more 'oomph'. Same principle as the overdrive but if you get a clear boost it won't alter the tone of the amp + guitar combo.
Cattivo Ragazzo
gainist pedals
« Reply #11 on: January 12, 2006, 11:04:53 PM »
Could you give me a bunch of names for these boost pedals? Thanks
willo
gainist pedals
« Reply #12 on: January 12, 2006, 11:29:00 PM »
I have the Catalinbread Super Chili Picoso. It has 35db of boost available, and its a clean boost. He also produces a Sogrando Picoso (?) that has an increased midrange boost. Either way, 35db is a lot of boost. It works fine for me, but I only ever used it on my Line 6...(there are samples in the players bit). I, for some reason, haven't used it with my JCM800 - I don't have an attenuator at the moment so I don't like the overdriven sound of the amp at room level, so for my distortions right now I mostly use a fuzz. I reckon though, with a properly overdriven amp, it would sound wicked. I'm getting my hands on an attenuator tomorrow hopefully, I should be able to report back!
Most boutique guys make boost pedals, basically cos I think they are a very simple circuit!
Some names to search for:
Cusack, Keeley, Monkey FX, Dytone, Build Your Own Clone, Retroman, Aramat, HBE, Fulltone, Kaden, ZVex, D*A*M.
There are loads though, including the MXR Micro Amp. The different boosters will have different tonal qualities and different amounts of boost, and therefore power. It's quite an organic effect, and you might find something you like, you might not. You can boost with a standard overdrive pedal too, though, by increasing the 'level' button. Of course, thats probably not a standard boost and maybe won't be so good at it...Also, some overdrives now come with built in, independent, boost circuits. Lots of choice!
Cattivo Ragazzo
gainist pedals
« Reply #13 on: January 12, 2006, 11:33:58 PM »
thanks
Cattivo Ragazzo
gainist pedals
« Reply #14 on: January 13, 2006, 09:56:01 AM »
Would changing the tubes make any difference? Could I get tubes that would make lots more gain? Mine are ecc83 12ax7a
