Started by nfe, June 24, 2011, 12:56:12 PM
Quote from: FELINEGUITARS on June 26, 2011, 10:53:04 PMAs I hinted at before ....Here is one I made earlierI do have a thing about flying Vs and will happily make them The shortest floyd block that can be supplied as standard is 32mm and that should be fineAny thinner and you end up with the issues that Philly Q poined out of the spring cavity breaking through into the back of the pickup cavities.But you can still get away with the typical 70s V thickness of about 38mm (I know Blackmachines are only about 30mm but the aforementioned issues with cavities for springs have tobe taken into account
Quote from: Loomer on June 28, 2011, 12:15:31 PMQuote from: FELINEGUITARS on June 26, 2011, 10:53:04 PMAs I hinted at before ....Here is one I made earlierI do have a thing about flying Vs and will happily make them The shortest floyd block that can be supplied as standard is 32mm and that should be fineAny thinner and you end up with the issues that Philly Q poined out of the spring cavity breaking through into the back of the pickup cavities.But you can still get away with the typical 70s V thickness of about 38mm (I know Blackmachines are only about 30mm but the aforementioned issues with cavities for springs have tobe taken into accountThatsound you hear off in the distance is the sound of Madsakre soiling himself and masturbating furiously at the same time.
Quote from: K-Roll on June 28, 2011, 11:50:14 AMgreetings from Slovakia :) congrats, it definitely is one hell of an extraordinary instrument to get.. some time ago I was thinking of getting one but the lead times made me not to.. when I imagined the amount of money I'd need to pile and the total lead time I just thought it isn't worth those nerves :D pls make some clips if possible.. what amp are you running?
