Gibson guitars consistency :-)
Started by Alex, August 15, 2011, 07:15:44 PM
I'm not saying EMG's are bad pickups, but so many brands have launched low- to mediumbudget guitars with EMG's. Not to speak of Duncan Designed.
Transcend
Quote from: Telerocker on August 16, 2011, 08:45:14 PM
Its a  good way to achieve consistent good sounds.
EMG basically get in bed with all the manufacturers and whore their wares out cheaper than anyone else will.
Then theres the 7 string thing going on the same manufacturers but a different size to 90% of replacement pickups which makes more people end up using EMGs to avoid the hassle of changing them.
It also works the other way though some people refuse to buy them because of the non standard sized pickups
Transcend
There is also the fact that pickup choices in new guitars generally boil down to 3 options
Custom pickups from the manufacturer which generally suck
EMG 81/60 81/85
SD JB/59
Yes, seems so. Maybe once you have BKP's, you are spoiled. For the time being I don't look at Dimarzio's etc.
Crunch
I know it will never happen, but I'd like to see manufacturers start selling empty instruments.
The new trend, it seems, is to make the best cheap instrument and gear (I suppose, since no one has money). I've never had a cheap instrument I didn't gut out, at some point.
I'm sure I'm the only one who actually wants this, however, and this would never be marketable.
Praise the Sunn.
Quote from: Crunch on August 17, 2011, 01:10:13 AM
I don't think it'll ever catch on big-time, but there are some sellers on eBay doing this, albeit usually with used and/or slightly damaged guitars.
I know what you mean, though.  A lot of the time I not only replace pickups and electronics, I also change most of the hardware - straplocks, locking tuners, TonePros bridge and tailpiece studs, aluminium tailpiece.  It's hardly worth having the original parts in the first place!  :lol:
Crunch
I've seen some stripped out Gibsons and the like on eBay, myself. I noticed a horrific trend of pulling the neck off, too.
Buying used makes me nervous unless I can inspect it, first. Course- it's the only way I would ever buy a Gibson.
Praise the Sunn.
+0.5
I'd happily buy guitars with no pickups in. Need everything else to get strings on to be able to check the quality/character of the acoustic sound of the guitar.
LTD are by far the worst for it in my experience; they will make danmed sure the guitar has a nice paintjob, often a marketable Name Player connection (if not a sig, a stripped down relative of one, or the same basic design and people connect the dots themselves) and usually EMGs (I like EMGs a lot, no problem there)...meanwhile the woods and construction are more often than not complete garbage (again, in my experience, but its of dozens of the bar-stewards, of which only a handfull have been acceptable instruments, fewer still genuinely good)
Ibanez are among the best; the pickups are cr@p and the hardware is usually good (if sometimes not; edge III for example) but I see a much greater proportion on them that are well made from good woods, and so have the basis laid for a good guitar. People often complain about the pickups, but I couldnt care less, and like it in fact: I've never even left in the pickups that came in the guitar when I got customs and chose the bloody things in the first place.
Prawnik
I've said it before, but Gibson QC has always been really hit or miss, even back in Elder Days when Gibson guitars were crafted by actual live Elves.
Still, that inconsistency is a large part of their charm for me.
mikeluke
Mules, Riff-Raff
There is a hint of that, I must admit!  :lol:
