Author Topic: Please compare the Warpig 7 to the Cold Sweat 7!  (Read 4233 times)
Emperoff
  • Hasta la vista, Baby!
Re: Please compare the Warpig 7 to the Cold Sweat 7!
« Reply #15 on: September 11, 2011, 05:00:19 PM »
Never thought about the Emerald 7 myself. The tone charts definetly make it look like a bright $%&#er so It would be interesting to hear hi-gain or reamped clips.
K-Roll
« Reply #16 on: September 11, 2011, 07:06:45 PM »
this sounds like an interesting idea Nolly, trying some of the medium hot series..  According to your opinion does the emerald 7 still retain 'body' while being bright? cause looking at the chart, i'd say it would be thin as a final result..
 here's my thing- I used to have a painkiller 7 in my guitar which used to sound great with some amps, but i found it too shrill with a piercing upper mid spike and with my boogie mk5, it just did not sound pleasing and had that terrible quack on upper strings..
 then i switched over to a holydiver7 which made a better result and instantly gave me a push in the lows and 'body' but   not in those FQs i was thinking it would.. the deal is that even with the bass side of the pickup being lower than the treble side, there's still too much bass and less definition as if it was trying to fight with my guitar's natural voice :) if i leave it too low, the sound looses compression and becomes rounder, which just sounds weird with staccatos and with the whole PUP being too high the bass gets even more present and does not allow higher pitched strings to sound even once i reach out for comples chords..
so  at least I know that  I should be looking for something with alnico 5 which sounds less shrill than the ceramic painkiller but with a simlar sound in terms of compression and tightness but with less quack, less harsh spike and more 'chug'.. so my idea would be- A-bomb or Emerald7 or VHII7
Nolly
  • Global Moderator
« Reply #17 on: September 11, 2011, 10:56:11 PM »
Well, you're certainly not going to get anywhere near the same level of compression as a Painkiller from the Emerald, but I think you'll find the Emerald has a noticeably smoother extreme treble despite the high rating on the tone chart. That said, I think if you were to be going for something along those lines the Rebel Yell might be a better choice - a little hotter and fuller sounding
