Author Topic: Oh my, what have I started?  (Read 6336 times)
Re: Oh my, what have I started?
« Reply #15 on: September 30, 2011, 09:32:45 AM »
Yeah I think the Intellifex will be great, and it's such good value for money. Any rocktron unit actually will do fine. Unless you go all out crazy and get an Eventide Eclipse for harmonizing and modulation, a TC2290 for delays and a Lexicon PCM91 for Reverbs. But for that kind of rig you should drop the loop and get a second poweramp, a pair of Bogner Cubes and go W/D/W.
« Reply #16 on: September 30, 2011, 09:51:40 AM »
Suppose to a cheaper axe-fx in the works that doesn't do amps, just effects ;)
That sounds interesting - especially if it does cab sims / IRs
Loomer
« Reply #17 on: September 30, 2011, 10:44:22 AM »
I would not mind having one of those, at all.
However, the TC Nova System does look mighty nice!
Transcend
« Reply #18 on: September 30, 2011, 01:34:12 PM »
I would personally go for the rocktron Xpression
it keeps your signal entirely analogue unless you use the noisegate on it.
And the effects are the best ive heard from a multi unit by far
JacksonRR
« Reply #19 on: September 30, 2011, 01:43:07 PM »
'Bout time. There's a lot on those units besides the amp sims.
JDC
« Reply #20 on: September 30, 2011, 04:31:09 PM »
No idea how far away they are from final production but I believe the axe-fx 2 has 2 main processors in it, one is dedicated to amps and the other for everything else, can't be that hard to split it in half!
