Author Topic: Is there something between NB and HD?  (Read 3623 times)
Emperoff
  • Hasta la vista, Baby!
Re: Is there something between NB and HD?
« Reply #15 on: October 05, 2011, 01:47:52 AM »
About the Alnico (neck) Miracle Man when I asked Tim about it:
Quote from: Tim
If a MM neck is used in the bridge the bass response would be considerable, especially on a maple neck thru. The Holydiver would be better suited as the bottom end wouldn't be so dominant. the other option would be to go for a Nailbomb but with ceramic option - this will give you the tighter bass response necessary for a neck thru and not be as compressed as the higher output MM.
It's the use of Alnico V with that wind in the bridge position that drives the bass that much harder. It wouldn't produce as much bass response as a Warpig.
If the HD isn't tight enough for low tuned metal(check out the metal clips - it's tight as a nut and I use it in a LP in drop C# with no problems at all)then using a Miracle Man neck or Aftermath neck would be just as bass heavy.
« Reply #16 on: October 05, 2011, 03:33:29 PM »
Makes sense - thanks for posting.
Alex
« Reply #17 on: October 05, 2011, 06:26:33 PM »
To be honest I think the Black Dog is closer to the HD and NB than the MM, because it has a strong mid range peak similar to the HD and NB.
I think if you like both the HD and NB in general, the chances are very high that you'll also like the Black Dog.
The Miracle Man, on the other hand, I would group with other pickups with different tonalities. The low end chug on the MM is in a different league compared to the HD.
« Reply #18 on: October 05, 2011, 07:18:49 PM »
the black dog was almost the the tonal opposite of the nailbomb in the same guitar
low volume, a ton of mids, tamed and friendly high end
the nailbomb was LOUD, didn't have much mids and had a very aggressive and strong top end
the dog was somewhat similar to the holy diver, but a lot darker and lower output as well
sixgunsovertombstone
    • Check the epic shred
« Reply #19 on: October 05, 2011, 09:37:42 PM »
Hmm this is very enlightening. I really like the Holy Diver... If there was a slightly more aggressive version with a little more attack I would love it a lot. Could this be accomplished with extra winds or something?
BKPs: Nailbombs, Ceramic Nailbomb, Holy Diver, Rebel Yells, Blackhawks, Aftermaths
ElectricTurkey4369
« Reply #20 on: October 05, 2011, 09:43:18 PM »
Maybe a Ceramic Holydiver?
Alex
« Reply #21 on: October 05, 2011, 11:36:31 PM »
Different guitars can obviously make a big impact on how they react. I just wanted to stress that the difference to the Miracle Man, at least to my ears, it much bigger then between the three Alnicos, especially with some gain added.
