Quote from: choucas09 on October 24, 2011, 11:56:31 PM
http://albertobolocanmusic.blogspot.com/2011/03/maple-neck-wood.html
yes, i have seen that - similar info on the musikraft website, which is used generally for sales purposes. is it odd that they don't mention the one major downside to a quartersawn maple neck - it doesnt hold a screw as well as flatsawn... that is quite an important point for fender style necks. just because its on the internet it doesn't make it true
we know quartersawn/flatsawn refers to the way its cut - there is no standard saying lower trunk wood should be cut quartered whilst higher up the trunk should be cut flat ??? infact what almost all saw mills do is slices straight through the tree producing a mix of quartered and flat, from the same part of the tree. its the easiest and most economical way to slice a tree - selection is the key
QuoteQuarter sawn and flat sawn woods are cut with a different grain orientation and come from different areas of the tree.
so yeah, i would say that is balony. if you look at the later diagrams on how to saw these you will notice it says nothing about using certain areas of the tree for certain cuts
Quote
This greatly affects the internal strength of both and subsequently, the quarter sawn neck tends to be a tighter grain and allot stronger and more stable than the flat sawn.
why is it tighter grain? even in the pics used both pieces of wood have areas of tight grain and wider grain. and the distance between grain lines is not that different. that is is on a picture used to illustrate the differences
so yeah, i can definitely agree with stiffer, i can definitely agree with tonal differences - but the only reason for extra density is that maybe it can have extra grain lines ... but that will obviously vary massively between trees anyway. . density will affect tone, but why does turning it 90 degrees make it denser???
so yeah, not trying to be an arse about this, but i would have liked to hear it from the horses mouth and hear Eldreds justification for maple being denser when its turned 90 degrees.
