BBE sonic maximiser
Started by roland_rat, November 14, 2011, 06:21:00 PM
roland_rat
Thanks for all the advice guys.  I will have a trawl of ebay and see if i can pick a 2nd hand one up.
choucas09
Yeah, I'll have a look around, the thread's got me interested.
horsehead
Is it similar to the Xotic EP booster?
Transcend
I've just ordered the parts in to knock one of these up and hopefully the IC's will arrive before the weekend so i should be able to give you my actual feedback on sat/sun
JacksonRR
Quote from: horsehead on November 15, 2011, 08:37:25 PM
No. The Xotic EP booster's main feature is the subtle harmonic content it adds to the signal. The BBE realigns the high and low frequencies so they hit the speaker at the same time.
roland_rat
Quote from: Toe-Knee on November 15, 2011, 08:40:48 PM
Cool I will be intrested in hearing how you get on.
Transcend
Quote from: roland_rat on November 15, 2011, 09:07:17 PM
Ill post some full feedback.
This is for the sonic stomp though not the rack one
asianaxeman
#22
just get the sonic stomp, cheap, small, you won't know till you hear it, it's great! esp for tightening up bass if you're a metal player/chugger. The best analogy I can think of it's like upgrading from a seymour duncan to a BKP, more clarity and sparkle for clean and distortion. If you don't use it right you will end up scooping your tone, unless you want that. Dials at 12 o'clock work fine and are a starting point. I sometimes notch up the bass to 1-2 o'clock. It's an 'always on' type of pedal. Works best for me in my serial loop of my engl or marshall.
