Author Topic: RECOMMENDATIONS FOR ULTIMATE HEAVY METAL HUMBUCKER FOR FENDER STRAT  (Read 5367 times)
Re: RECOMMENDATIONS FOR ULTIMATE HEAVY METAL HUMBUCKER FOR FENDER STRAT
« Reply #15 on: December 22, 2011, 01:10:13 PM »
As regards the pots - if you have 500k in them, you can solder a 470k resistor (can be 1/4 watt, there is not much this resistor needs to dissipate) from the tap on the 5-way-switch to which the coilsplit connection (that would be the green and white wires soldered together) is connected, and the output lug on the switch. With this set up you will have a 500k volume pot when the humbucker is selected, and a close to 250k pot when any single coil combination is selected.
As regards pickups - I still think you should go for a ceramic, so Miracle Man or C-Bomb.
Rabid Gerry
« Reply #16 on: December 22, 2011, 02:07:59 PM »
I think I am going to get a Miracle Man.
I will be placing my order  after Christmas and when I do and install these pups I'll post some clips (hopefully).
As fas as pots go I'll restore my tone controls back to middle pot for neck and middle pup, then 2nd tone control for the bridge
at the minute I have the 2nd tone control for bridge and the middle.
I'm gonna modify some pots I have to create around a 550k and 280k version of them (scr@ping away a little crabon works)
Keep 'er Lit
