Author Topic: d.i.y. pedal kits (anyone tried these)  (Read 10494 times)
Re: d.i.y. pedal kits (anyone tried these)
« Reply #15 on: December 27, 2011, 08:37:42 AM »
Being a technical numpty, the BYOC pedals are the only ones I've had any success with.
bandmaster188
« Reply #16 on: December 28, 2011, 09:47:25 AM »
i think i will be going for a byoc pedal but now i've gotta choose which one.
i like the look of the mouse distortion which has got a rotary pot for 6 different drive sounds. the other one i like is the overdrive 2 which is an overdrive/boost. anyone had any experience with these.
The swamp city shakers
Transcend
« Reply #17 on: December 28, 2011, 11:30:02 AM »
I have some experience with the classic overdrive.
it turned out to be a pretty accurate TS clone and sounded pretty damn good.
I have some info on it on here
http://www.toboy-diy.blogspot.com/2011/03/ts808-complete.html
http://www.toboy-diy.blogspot.com/2011/02/well-at-least-something-arrived.html
juansolo
    • Juansolo's Gnomepage
« Reply #18 on: December 28, 2011, 01:18:17 PM »
The OD2 is a tube screamer with more mods than you can shake a stick at. It's pretty good, but possibly a little over complicated (surprisingly) for what you need. I'd get a BYOC under your belt then start looking at doing your own (Mouse looks fun).
There are a few simple principles you just need to get down that apply to most pedals (wiring up a 3PDT stomp LED and power) that when you've got that sorted, dropping effects into a box becomes relatively easy. So do that, then do a SHO on vero (brilliant little boost, bugger all parts). This is our version of it that uses an obtainable in the UK pot and is less likely to blow the transistor every few months. Still worth socketting the transistor for paranoias sake:
Some tips:
- Keep your tip clean ;) works on so many levels
- Get a solder sucker, very useful things
- Get a good set of small pliers and side cutters
- Helping hands help (little stand with croc clips on it)
- Take your time, fit the smallest components first and work up in size, this will make sense why when you do the BYOC
- Get a cone-cutter and a pillar drill press, you would not believe the amount of time this will save
- Read my decalling guide (though we do this differently now... I'll have to change that), but it'll give you an idea of what you can do with sticky decals and car rattle cans. There are other methods of finishing. You can paint, etch or just write on it, all depends on what you're going for.
- Get a good desk lamp
- Get a vero track cutting tool (looks like a drillbit with a handle)
As you progress, for testing/diagnosis:
Get a multi-meter
Make an audio probe
Make a little test box with spring clips on it to test a circuit before you box it (yeah, I STILL need to do this! it would save so much effort)
« Last Edit: December 28, 2011, 02:11:19 PM by juansolo »
bandmaster188
« Reply #19 on: December 28, 2011, 01:57:07 PM »
do you think the overdrive 2 is a bit ambitious for a first time build?
i'm pretty good with a soldering iron but have never done a pedal before, just pickups and the odd simple amp repair. i just fitted new pickups in a 335 and i'm sure that qualifies me to work as a N.A.S.A. engineer or am i getting ideas above my space station!
juansolo
« Reply #20 on: December 28, 2011, 02:06:59 PM »
Oh I don't think it's a difficult build, I just think it's an over complicating an effect that doesn't need or want to be complicated. I'd build a straight TS808 clone over the OD2. I find millions of knobs and switches on pedals to be a pain and keeping things simple is often the most usuable/useful way of doing things. Put it this way, it was the first effect I ever built. I never used it so gave it to my brother. I recently built a straight TS808 clone that I much prefer. Too much choice is not neccessarily a good thing.
« Last Edit: December 28, 2011, 02:13:04 PM by juansolo »
