Author Topic: Heavy Rock with AV Nailbomb  (Read 6092 times)
lyonk55
« on: January 24, 2012, 10:05:36 PM »
Here's a quick rock song I put together a few days ago. Can't get the bass to be quite as clear and punchy as I'd like, but overall I think it turned out ok. Excuse the lack of title.
Nailbomb bridge > Tanglewood LP copy > MXR Wylde OD > Engl Screamer combo > AKG D770
BigB
  • Let's rock !
Re: Heavy Rock with AV Nailbomb
« Reply #1 on: January 27, 2012, 09:31:04 PM »
I found mine to sound clearer (without loosing the punch and "in your face" character) when set not too close to the strings (and a bit slanted to keep the highs thick enough).
Still a good example of the ABomb's low mid roar,  thick but not fatty and really abrasive.
I really love this pickup, much more versatile than you would expect - I suspect the ones labelling it as "90s metal one trick pony" never tried it set low, volume pot rolled off a bit (50s wiring and PIO cap) and plugged into a rather vintagey (I mean: "not modern hi gain") amp. It cleans up beautifully to a sparkling about to breakup tone without getting thin or dull and still cuts thru the mix.
lyonk55
« Reply #2 on: January 27, 2012, 10:42:27 PM »
Thanks for the tips, but it was more the bass guitar I was meaning  :lol:
But I agree, the Nailbomb is great. Not sure if it's the pickups or guitars, but the Nailbomb/Cold Sweat combo sounds much better than my EMGs and Miracle Men (although, that might be the really thick strings and cheap pots being the problem there).
BigB
  • Let's rock !
« Reply #3 on: January 27, 2012, 11:15:35 PM »
woops :oops: Sorry.
lyonk55
« Reply #4 on: January 28, 2012, 12:38:08 PM »
Not a problem
  • Brokeback is back
« Reply #5 on: February 02, 2012, 04:44:31 PM »
Nice roaring and mean tone.
AnnunakiMassacr
« Reply #6 on: February 02, 2012, 05:00:54 PM »
How would you say the Nailbomb compares to the Miracle Man & EMGs for metal?
BKPs: ESP Eclipse I CTM FT w/Riff Raff bridge/Mule neck - ESP Eclipse I CTM w/Rebel Yells - LTD EC-1000 FT w/Aftermaths - Music Man JPIX w/Juggernauts
lyonk55
« Reply #7 on: February 02, 2012, 09:34:23 PM »
Untill I sort some wiring out, I'll not mention the Miracle Man yet: doesn't seem fair.
The Nailbomb isn't as high output as the EMG 85, but has a much clearer, less fizzy sound to it. Better note definition and doesn't distort as much (so has a much "cleaner" clean sound to it for the same gain settings). The 85 is bassier too I find, which is why I moved it from the neck to the bridge. Might just be my imagination, but the Nailbomb doesn't seem to get as ice-picky when the treble/presence is cracked a bit.
The EMGs are in a basswood Cort X-11. I tried the 81 in the bridge too, but it seemed a bit thin and harsh sounding, so it's in the neck now where it handles the lows better than the 85 did. I had noth BKP sets in there at one time too, but the actually weren't as good in this guitar, which is why I'm suspisious of the pots in my Epihpone - they came from the Cort when I swapped the EMGs over.
Also, thanks Mr Air. Much appreciated! :)
