Eric,
That sounds very encouraging indeed. I have a PRS-style swamp ash guitar which tends to compress the bass frequencies. Your description of the CS neck in the bridge sounds exactly what that guitar needs. Currently it has a set of WCR GWs in it. Even though I liked the Abraxas better as far as midrange and high end are concerned, the bass was just too much. The WCRs are the only pickup which does not overwhelm this guitar with bass response so far.
I will probably take out the Abraxas neck of the LP, pair it with the CS bridge in the other guitar and move the CS neck to the swamp ash.
Any idea what to use in the neck? Do you intend to keep the DiMarzio PAF?
