Author Topic: which od pedal  (Read 9986 times)
tekbow
Re: which od pedal
« Reply #15 on: February 23, 2012, 11:33:48 AM »
Eric Johnson = BK Butler Tube Driver (+fuzz face, but smooth tones can be had without)
also recommended is the sobbat DB-1. Smoothest sweetest sustainest OD i've heard and i've played and own a few including the tubedriver
froglord
Re: which od pedal
« Reply #16 on: February 27, 2012, 01:33:28 PM »
For smooth and sweet, the BB Preamp will do a good job.
Egnater Tweaker 15
Attica!
Re: which od pedal
« Reply #17 on: February 27, 2012, 03:42:21 PM »
Regarding Tube Screamers, can somebody PLEASE explain the difference between the Original 808 and the TS9?
Also the TS9DX, what does this Turbo model improve on the TS9?
Regarding the others, what does the Handwired 808 do that the original 808 does?
And one last question, what's the fuss about the Keeley moded?
tekbow
Re: which od pedal
« Reply #18 on: February 27, 2012, 04:17:17 PM »
Am up to my eyes at work just now, but if you can wait until tomorrow and no one jumps in first i can give you a decent low down on the keeley TS808 as i own a vintage chipped one. short answer, they're great but not worth the 279 quid that guitar guitar charge for the fully loaded mod
« Last Edit: February 27, 2012, 04:19:48 PM by tekbow »
Attica!
Re: which od pedal
« Reply #19 on: February 27, 2012, 04:22:47 PM »
Yh cheers that would be great. I just want to know how they all compare. I currently own a TS9, so I will have a good referance point to work frrom.
Re: which od pedal
« Reply #20 on: February 27, 2012, 07:08:33 PM »
jack shiteee is the simple answer regarding the 808 versus the 9. iirc, two resistors in areas of the circuit which shouldn't be audibly different.
there's a big article on the tubescreamer on the geofex site. I'd like you, but whatever software it uses doesn't let you link to a specific page, just the homepage (and i'm too computer illiterate to figure out how to do it :oops: )
i think the handwired was an excuse to get £300 out of TGP types. heck the bog standard tubescreamers are way overpriced in europe already. you can get a clone for £25-£50, which if you're using it as a boost, will, odds are, sound identical.
EDIT: oh right you already have a 9. Yeah just keep the 9 and use that. you're overthinking it, i think. :lol: (yes i'm aware i'm guilty of overthinking things too all the time :lol: )
« Last Edit: February 27, 2012, 07:10:08 PM by dave_mc »
Attica!
Re: which od pedal
« Reply #21 on: February 27, 2012, 07:14:07 PM »
jack shiteeeee is the simple answer regarding the 808 versus the 9. iirc, two resistors in areas of the circuit which shouldn't be audibly different.
Well I'll only have it a few more days as I had to get rid of it as I'm in a money crisis until next week as my main guitar broke so I'm trading it with my guitar tech haha. So obv I'll have to buy something else come next week. I actually only use it as a boost. What's the Turbo version of it all about? And which are these cheap copies? Is it the Joyo mentioned earlier?
« Last Edit: February 27, 2012, 07:15:41 PM by mbchepburn »
BigB
  • Let's rock !
Re: which od pedal
« Reply #22 on: February 27, 2012, 07:46:14 PM »
jack shiteeee is the simple answer regarding the 808 versus the 9. iirc, two resistors in areas of the circuit which shouldn't be audibly different.
Yet it makes an audible difference. The TS9 has a really honky mid-peak where the 808 is more balanced and more open sounding and this really comes from these two resistors values. The TS9 works better for higher gain tones (tighter lows and more mid boost) but I personnally prefer the 808 circuit.
wrt/ exact chip used, I wouldn't say it doesn't make any difference but really nothing compared to the difference you'll get from the caps and resistors tolerance variations - IOW, that's mainly snake oil and marketing bullshitee.
Oh and yes: the very best variant of this circuit I've ever played is the techniguitare.com Custom Screamer kit (french site, sorry), comes with the componants for both (TS9 and TS808) versions, it's deliberately not a true clone - there are a couple well tought-out variations on some componant values - and this thing just beats any other TS I've ever played pants down. Kicked my good old vintage TS9 (the only pedal I used for more than 15 years) from my pedalbord, 'nuff said.
richard
Re: which od pedal
« Reply #23 on: February 27, 2012, 09:46:51 PM »
Blackstar HT Drive is a really nice pedal.
PRS S2 Singlecut RY's
JV Strat  IT Bridge
Gibson SG JB bridge
Fender Bassbreaker 15
Yamaha THR 100 Dual
Quilter Aviator Cub
Toe-Knee
    • DIY Audio
Re: which od pedal
« Reply #24 on: February 27, 2012, 10:01:28 PM »
wrt/ exact chip used, I wouldn't say it doesn't make any difference but really nothing compared to the difference you'll get from the caps and resistors tolerance variations - IOW, that's mainly snake oil and marketing bullshiteeee.
The ICs actually do make quite a large difference. Some are higher/lower output with higher/lower power consumption and some are higher/lower noise
The NE5532 is my personal favourite but its a complete write off if you want to use the pedal with batteries as it chews through them in no time.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
Re: which od pedal
« Reply #25 on: February 28, 2012, 12:21:59 AM »
jack shiteeeeee is the simple answer regarding the 808 versus the 9. iirc, two resistors in areas of the circuit which shouldn't be audibly different.
wrt/ exact chip used, I wouldn't say it doesn't make any difference but really nothing compared to the difference you'll get from the caps and resistors tolerance variations - IOW, that's mainly snake oil and marketing bullshiteeeeee.
i'm not saying having a different chip (which some of the ts9s had, i think) makes no difference, as i had a biyang ts-alike which had swappable chips, and they made a noticeable difference. I'm saying more what you're saying in the second paragraph, which is that, assuming the same chips, i wouldn't worry about it. :) Especially when you consider the differences in price between the 9 and the 808- or maybe more importantly, between them and the cheap clones, which ironically often use the "right" chip.
yeah far as i'm aware the joyo is an 808 clone. it's (supposedly) true bypass, so it might be missing the buffers (dunno), but it sounds like a ts to me (not having one beside it to compare to).
tonerider does one too, but dangleberry seems to be out of stock.
that geofex site explains the difference with the turbo, too.
tekbow
Re: which od pedal
« Reply #26 on: February 28, 2012, 06:23:52 AM »
the guys have covered the TS9/TS808 differences etc, there's more info here:
http://www.analogman.com/tshist.htm
While the chips make a difference, i don't think they make anything like as much difference as corksniffers reckon they do, i think the vintage JRC4558D thing is a way to justify charging more money. the variations of the 4558 chip are all pretty good, vintage or not.
The Keeley pedal tubescreamer.. well.. my opinion on it may be coloured as i was lucky enough to get a vintage chipped true bypass, mod plus one off the bay a few years back for what turned out to be a total steal compared to what they go for new, so am guessing the prices new were not even remotely close a few years back.
Anyways.. i digress. the Keeley (and analogman silver mod) both tighten up the low end (previously flabby) gets rid of the mid range hump (there is still a pronounced midrange as that's what a TS sounds like, but makes it less nasal and honky), gives you more range on the gain knob (at the lower end it's way way cleaner and at the top end there's more gain available), makes the pedal true bypass, and generally upgrades a lot of components for higher quality ones so you get less noise.
The fuss is that these companies are very good at marketing, and while they do improve these pedals in some cases considerably, I am just starting to not be convinced by how expensive the prices are starting to become:
http://www.guitarguitar.co.uk/pedals_s_detail.asp?stock=06061010482429
to put that into context i got mine for about 130 quid used on the bay with a vintage JRC (as i mentioned) . There's corksniffers out there would and have literally creamed their pants and offer me stupid money for it. not that i would get rid of it. To be honest if i was going to spend that money on a pedal i would buy an analogman KOT, or the tubedriver. If i wanted a modded TS808 now i would get in touch with these guys.
http://www.pedalmods.com/
and if i wanted a TS9 or TS 808 i would but an old one of the bay from the 90's or early 2000's
Just saw the prices of the current ibanez reissues, so i take back what i said about Keeley's prices, they only cost £40 more than the base price of the basic pedal.. I can't believe how expensive the ibanez reissues have got. It's less of a question of whether the mods are worth it and more a question of is a tubescreamer worth it. I would say no, there's better pedals for less money.
Elliot
Re: which od pedal
« Reply #27 on: February 28, 2012, 12:25:32 PM »
I have mucked around with op amps and whereas I would agree the user can tell slight differences (i.e. I noticed that Burr Browns are 'cleaner'), it is questionable if in reality the difference is as noticeable as the people who write reviews like 'the JRC4558 lacks the subtle distortion swirl of the TL072 la la la ...... I think there is more change in tone in pedals based on the inherent differences in tolerances of the components.
- I am sure you have all seen this:
http://www.youtube.com/watch?v=bpTv2jAree8
tekbow
Re: which od pedal
« Reply #28 on: February 28, 2012, 12:51:23 PM »
Can't really argue with that. Keeley included a TI4558 chip with the TS808 (glued in on the inside in a little socket). might switch them out for a laugh and see what happens.
The first statement he read out was from Keeley, Am glad i got mine for the price i did, because if i had have paid what some people have offered me for that pedal then watched this i would have been very very disappointed..
actually if you wanted an 808 type pedal that visual sound based on the reviews say would be a very likely candidate if you didn't want to shell out 139 quid for a TS9 reissue.
« Last Edit: February 28, 2012, 12:56:22 PM by tekbow »
tekbow
Re: which od pedal
« Reply #29 on: February 28, 2012, 01:19:05 PM »
http://www.youtube.com/watch?v=nCZ7b5hqaxA
yep.. visual sound at 120 quid less than a TS808 reissue and 60 less than a TS9 reissue does it for me
