Blackhawks????
Started by TheyCallMeVolume, April 18, 2012, 12:30:11 PM
Quote from: FELINEGUITARS on May 01, 2012, 08:20:46 PM
Quote from: AndyR on April 30, 2012, 08:30:05 AM
I'm looking forward to when/if Jonathan (Feline Guitars) has anything to say. If he's got some on order for stock, I'm convinced he'll be putting a set into something to see what they do...
I'll have a few sets in shortly and will maybe get them into a simple guitar so you can hear what the pickups sound like.
I'll get a set in something like our Pantera model or maybe get Doug to put a set in one of the Blackmachine B6s coming through.
That's cool, it'll be interesting to see what you make of them in a swamp ash(?) guitar with a bolt-on neck.
James C
Quote from: Philly Q on May 02, 2012, 02:12:00 AM
I'll be putting more stuff up in seconds out this week, as soon as it's sold i'll be dropping Jon a line as blackhawks will be perfect (hopefully) for the project i have in mind
Formerly "ManOnTheEdge"
Then I will be able to evaluate what they sound like with my style of playing, rather than in the hands of an accomplished shredder like Nolly.
That's exactly how I was feeling :lol:. Although, I got a very pleasant surprise about his playing that morning. In the same session, seeing as I was on a PC that could handle streaming ok, I checked out the BKP tutorials... Nolly, you're a blues-monster as well!! :D (what are you playing all this widdly stuff for if you can do that?! :lol: :wink:)
I would like to hear then with out the mix as in the Red Seas Fire clip the keyboard line playing in unison with the guitar distracted me somewhat as to what the guitar actually sounds like ( I used to have the same problem with Deep Purple - what I used to think was cool guitar riffage was often John Lord's Hammond organ overdriving often mirroring Blackmores strat.
I also thought this... and funnily enough, I've just been posting something similar about Deep Purple on another site. For years I was making the same mistake as most guitarists do/did with "that" riff. Most of what we think is distorted guitar is actually Jon Lord on "The Beast", and the guitar part of the riff sounds LOADS better (and more aggressive) if you play the minimal that Blackmore did...
Quote from: allstar100595 on May 01, 2012, 08:28:49 PM
I have made that mistake SO many times....starting to doubt Blackmore was even in the band. lol
:lol: I went through a period of that and then I saw a program about them. I think it was the Classic Albums episode on Machine Head, and Roger Glover was showing us what was in the mix and highlighting these stunningly simple things that Blackmore added that just made the track. When he was playing "rhythm", he truly was a rhythm guitarist. Most of us add harmony when we're rhythm guitarists, he didn't need to when Jon Lord was there, so he concentrated on being part of the rhythm section and adding excitement in that area.
OUR BLACKHAWKS HAVE ARRIVED
WHOO HOO!
Pics or they don't exist!
(And I know you're good at pics, Jon!  :D )
Quote from: Philly Q on May 02, 2012, 11:20:44 AM
You'll be pleased to know that one set are already in a guitar - just wiring it up now! :P
itamar101
Quote from: FELINEGUITARS on May 02, 2012, 11:46:36 AM
Sweet! I'm patiently waiting for the review!
itamar101
Oh, also, is there any chance that you could wire this for coil split so that youre using one single coil sized humbucker instead of a "double-bucker" and telling us how it sounds.
Also, I'm not sure that this is possible with only 4 conductors... but would a "double coil-split" be possible so that we could use only one single coil/blade rather than 2 or the standard 4?
Quote from: itamar101 on May 02, 2012, 12:19:04 PM
Didn't I read somewhere that it's made of two coils, like a standard humbucker, each coil having two blades? So wiring splits would be just like usual...
Or have I got that wrong?
Brow
Any chance of any clips at all Jon?
I'm very interested in how these sound through an amp instead of direct through a modeller.
Plus I know we have very similar tastes in music, so I know I can trust your opinion  8)
Quote from: AndyR on May 02, 2012, 12:25:12 PM
I think you're right, Andy.
Even though there are two blades in each "half" of the pickup, they're NOT side-by-side SC sized humbuckers like Bardens or DiMarzio Fast Tracks.  Just single coils with a pair of blades instead of polepieces.
Here ya go!
First impressions are VERY GOOD
I much prefer it to the aftermath, which was the last release.
It sounds very open and clear with almost an extended, but usable frequency range.
It sounds a bit like a Mule with a slightly improved and more even top and bottom end range.
It's like you recorded a guitar with a mule and then double-tracked with a good tele bridge pickup (yardbird or Boss perhaps) into the mix.
The bass is nice and tight and defined, but in no way lacking to my ears.
The output is kind of hot vintage without being overdone - maybe comparable with an Emerald or Abraxas.
They can do classic rock, 80s metal as well as the modern stuff (as demonstrated by Nolly)
As usual, I'll have to wait until I get home to see the pics.
But sounds very promising!
Can the neck do nice warm singing tones?  And is there a decent amount of contrast between neck and bridge?
The bridge has a single ceramic magnet whilst the neck has the trio of alnico 5s
Neck pickup with a loud plexi or marshall/soldano sound does sing - has a smooth kind of tone - not unlike the Cold Sweat neck - maybe a touch bigger sounding.
As already noted will be good for fusion stuff.
I think I might even experiment to see what would work in an H/S/S combo........maybe a trilogy or slowhand?
In time I'm sure some players will try combining a bridge Blackhawk with a traditional neck pickup too.
Would like to try it with a painkiller neck 8)
Quote from: FELINEGUITARS on May 02, 2012, 02:25:10 PM
As I've already mentioned, I hope Tim will consider making a Black Hawk single coil to match the humbucker.
Visually, it would be very cool!  :D
I am definitely liking the sound of these.  And formulating plans (.....never to be realised, of course!  :lol: )
