November 20, 2026, 11:07:12 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Guitars, Amps and Effects
Powertubes - need replacing?
Started by witeter, June 12, 2012, 08:33:16 PM
Previous topic
Next topic
Print
Go Down
Pages
1
2
User actions
witeter
Lightweight
Logged
Re: Powertubes - need replacing?
#15
June 14, 2012, 09:51:54 AM
Ok so ive swapped the outer tubes for the inner tubes and now the inner ones dont light but the outter ones do-hopefully this means its not the amp; so will order a new pair of EL34s and see what happens :-)
cheers again
[url="http://www.facebook.com/flailhead"]http://www.facebook.com/flailhead[/url]
[url="http://www.facebook.com/insunaband"]http://www.facebook.com/insunaband[/url]
[url="http://www.sabreguitars.co.uk"]http://www.sabreguitars.co.uk[/url]
Sabre Custom Wraith
Ibanez RGA42
Light Heavyweight
Logged
#16
June 14, 2012, 11:12:58 AM
Good luck - make sure you take it to a tech for a bias check :)
Welterweight
Logged
#17
June 14, 2012, 12:07:38 PM
You should get a matched quad otherwise the bias points on the old EL34's and the new EL34's could be pretty different, and you won't get all 4 working at an optimum.
witeter
Lightweight
Logged
#18
June 14, 2012, 01:12:37 PM
Cheers guys! the tube guy whom i get all my stuff from has asked me to ship him one of the good tubes and one of the bad ones-if the good one is indeed 'ok' then he will make sure 2 new tubes are shipped out with matching bias to the existing ones-if not then itll have to be a quad. He should get them tomorrow so will have some more info then :-) oh and ive also ordered a multimeter to do my own biasing. The tube guy is such a gent he even offered me to talk me through it via phone to make sure i bias the amp correctly! Check our Karltone for tube stuff, he is awesome
Sabre Custom Wraith
Ibanez RGA42
Welterweight
Logged
#19
June 14, 2012, 01:20:27 PM
Aaah! Good plan sending him those valves. Let us know what he says.
TheyCallMeVolume
Welterweight
Logged
#20
June 14, 2012, 02:52:30 PM
Which ones are ya getting?
witeter
Lightweight
Logged
#21
June 14, 2012, 03:26:05 PM
JJ EL34's as those are the ones the Peavey comes with from stock i believe
Sabre Custom Wraith
Ibanez RGA42
TheyCallMeVolume
Welterweight
Logged
#22
June 15, 2012, 05:22:12 AM
Not too bad. I'd do a little research, there's alot you can do with a different set of EL-34's. EH, GT, Winged C, all make great EL-34's. I guess just matters what kinda sound you're after, but power tubes will help you get "there".
witeter
Lightweight
Logged
#23
June 15, 2012, 09:02:05 AM
Yeah cheers man, i know theres tons to choose from-just wanted to play it safe for now and as ive only got the amp i want to try it with 'stock' tubes and go from there :-)
Sabre Custom Wraith
Ibanez RGA42
TheyCallMeVolume
Welterweight
Logged
#24
June 15, 2012, 01:54:26 PM
Cool, I get ya. In the future, I definitely recommend it though, if not just to shake things up a bit.
witeter
Lightweight
Logged
#25
June 15, 2012, 10:29:10 PM
So powertubes were tested and theres nothing wrong with them-will wait to get them back and give it another go at rehearsals. maybe it just needs cranking way more than what i am used to- as i have read other posts of people having a similar issue-so we shall see, if not will try swapping some preamp tubes around.
Sabre Custom Wraith
Ibanez RGA42
TheyCallMeVolume
Welterweight
Logged
#26
June 16, 2012, 05:33:48 AM
Oi, hate when that happens. I'm not too sure what to suggest here :/
I guess the usual suspects like pre tubes, maybe a transformer, but not too sure here, just a shot in the dark.
witeter
Lightweight
Logged
#27
June 16, 2012, 12:51:26 PM
Its ok mate-thanks anyways; i think i need to give it another bash in the practice room and try a couple of things i have been reading up on as i think the key lies in the effects loop volume boost...a bit of a strange one but it seems that a lot of people recommend playing the head with the effects loop engaged (via the footswitch) the whole time-with the send and receive knobs maxed out to 10. This gives a huge volume boost and brings the amp to 'full' volume-without this you have to crank it to apparently insane levels to get anywhere near the volume required for say metal with a hard hitting drummer (when compared to some other heads anyways). Bizarre i know, but tried it briefly at home and the effects loop does provide a huge boost-so it could just be a 'getting used to the amp' issue. Will find out monday at practice :-)
Obviously if mic'd through a PA this wouldnt be an issue.
Sabre Custom Wraith
Ibanez RGA42
Print
Go Up
Pages
1
2
User actions
Forum Ringside
User actions
Print
