Author Topic: I vowed this would never happen...  (Read 34629 times)
Re: I vowed this would never happen...
« Reply #90 on: July 08, 2012, 05:50:52 PM »
you'd need an SG style 3 way toggle. (the tall style gibson toggle won't fit... too tall!)
The tone pot on mine was a push pull pot with DPDT switch. I think mine was a 16mm Alpha. It had a narrower bushing than the CTS pots. The hole in the body for it is a little wider than the bushing on the pot. I remember the washer off that sat on the top of the body being a little deformed.
You also need a 500K volume pot (i used a 550K BKP). with a 0.022uf tone cap, and a 180pf Volume Bypass cap.
There is a diagram made by PRS for converting 5 way to 3 way switching. I think one of the pickups in the 5 way rotary switch guitars has flipped magnets or something, so it's not as straightforward as I thought to rewire while keeping the original pups..
« Reply #91 on: July 08, 2012, 06:03:21 PM »
I've seen PRS sell a drop in kit but it costs £60+. What would I need to be able to have a Volume, Tone w/Coil Split and a Toggle?
Bear in mind that you'll have to enlarge the hole for the 3-way toggle switch, so it's not a reversible mod.
(Well, it's sort of reversible, but you'd have to use a couple of big washers or something to put the rotary switch back in the hole where the toggle switch was)
