Miracle Man Review
Started by Slartibartfarst42, July 01, 2012, 07:36:36 PM
The Cold Sweat would be a great option for the neck and is a popular choice to go with the Miracle Man bridge. I've used one before and it's great for shredding but has a very passable clean tone as well. Another option might be the Emerald neck which is getting increasingly popular as a neck lead pickup and it will have some lovely cleans too. I hear good things about the Holydiver neck too, though I've only tried the bridge model myself.
eighteen-0-nine
I'll have to start a thread shortly as many people who could give me great advice on this may not be following this thread. I will definitely ask about the Emerald though.
I listened to the VHII and Cold Sweat neck clips, and I found the VHII to sound way more organic with more feeling. But then again you can't judge how a pickup feels by the sound.
Cheers for the advice
BigB
Nice and detailed review, you made a good job, and I appreciate that you took some time to explain your reaction and feel about the ABomb (in fact I think you should add it to your first post, really).
You know ("you I and I we've been thru that" to quote a famous song) we just don't have the same experience of the ABomb - mine being in a rather dark SG  - and I think your mention of  "quite a bit of mahogany" must be what makes the difference. At least I and my band mates can testify that I get some great hard rock, classic rock from this guitar and pickup, and even bluesy tones when mixing it with the neck Mule.
But anyway - as I said, pretty nice review with enough context and balance to make it really useful.
Quote from: Slartibartfarst42 on July 03, 2012, 08:56:06 AM
I still don't think I've settled on the perfect pickup height. The Holydiver was best very close to the strings so does anyone have any insight on the Miracle Man?
I think I had it further than the diver, closer than the alnico nailbomb
having it close helps with the midrange, but you gotta be careful with the low E or the bass will flub out easily, considering it's a bassier pickup than the HD
I think it sounds a bit thin and weak far from the strings, so you it's a bit trickier to set the height on the sweet spot than the diver
Quote from: itamar101 on July 03, 2012, 04:32:31 PM
Remember that this review is on the miracle man bridge alone. Why not go for a "mix m match" set? A Holy Diver Neck and Miracle Man Bridhe for example.
That would not be a combination I want. The HD neck is a very clear pickup with quite low output. The MiM bridge has very high output. A Cold Sweat, Crawler, VHII or Emerald neck would be better matches. I even found the CS neck a bit too weak paired with the MiM bridge, and that pickup has more output than the HD neck.
Zaned
Quote from: BigB on July 03, 2012, 06:15:49 PM
I forgot to reply to this the first time I visited this thread. Funnily enough, I've had both of your experiences with the ABomb.
Two strats they are. First my strat (alder with maple top, maple + rw neck) the pickup is a bit closer to the bridge, and the guitar itself is bright and clear. I originally had the Abomb there, but it did have metallic edge to the tone which I grew to dislike. I put a HD there and it worked a lot better. Aggressive, throaty, but clear as water and very versatile. Can do anything.
Now the other strat, alder body and an all-maple neck: ABomb works wonderfully. The pickup is a bit further from the bridge than on mine, and the guitar itself has more center mids than mine. Chimey though, very clear. The Abomb just works there; it's thick and aggressive, but still manages to sound warm and woody. I guess that 'edge' that didn't work on my guitar, here picks up a clarity that works to get that woody tone I mentioned. Again, very versatile.
-Zaned
Paths are for followers.
charles55
Sorry for bumping up an old thread. I must say its a very detailed review.
Some questions, how does the Miracle man bridge when it comes to solos? Does it produce good harmonics / dime squeals easily?
I asked because I have an EVO7 in a 1527 Prestige. Solos are great, but I am not too sure about palm mutes & rhythms.
Thanks! - Charles
darrenw5094
Quote from: charles55 on January 10, 2015, 04:55:13 AM
Thanks! - Charles
I can't answer your question directly because i have never played a MM, but the Dimarzio Evo's are the worst pup for rhythym playing.
Funny enough though, BKP suggest the MM for Vai tones, but that is not exactly what you are looking for.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Out of the BKPs the MM has the best reputations for pinch harmonics and squeals and one of the best for tight riffing, so you should be set.  There are several reviews on here that talk about using the bridge pickup for solos, and it has done well there too.  I've never owned a MM, but I have long been tempted to get one to switch with my Cold Sweat bridge sometimes, and probably would have done it already except for the money and the difficulty of changing pickups in a large pickguard SG (you have to take the bridge out to do it and you lose all of your setup).
darrenw5094
Quote from: Agent Orange on January 11, 2015, 12:06:58 AM
Me either, but we live in hope  :wink:
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Surely if you just measure your action at the 12th fret (or last fret) with a set of feeler gauges and return it to the same height when reassembling the guitar is the answer.
The MM is the first BKP I got 10 years ago when it was one of only a small selection that were available (Cold Sweat hadn't been invented yet) and for me it was perfect for what I had been looking for (George Lynch's "Under Lock and Key"  tone).
The Miracle Man is more of a late 80s metal tone whilst the Cold Sweat is more of an early 80s tone - the former being thick in the low mids whilst the latter has it all going on in the upper mids and sounding a little scooped.
The Miracle Man bridge can also work really well teamed up with the Cold Sweat neck pickup (which is better for cleans than the Miracle Man neck)
darrenw5094
Does the MM and CS work in alder bolt ons or just the Mahogany Les Paul type guitars?
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
I just found this nice clip of a Miracle Man in a BC Rich Gunslinger
Still very tempted to fit one of these to my SG ... either that or buy a Gunslinger of my own ... there's a nice yellow one in my local shop
https://www.youtube.com/watch?v=bPjtspAW9KM
Quote from: darrenw5094 on January 12, 2015, 07:18:06 PM
I see absolutely no reason why it wouldn't work in alder. I've read plenty of good reviews of it working well in mahogany and when I wrote this review it was in a maple neck-thru. When I sold it I believe it went into a Strat and worked beautifully so it seems to be highly versatile in that respect.
